		Omega Help Area => Omega Electrical and Audio Help => Topic started by: I_want_an_Omega on 24 April 2010, 08:27:47
				My car has a problem where sometimes you can't take it out of park without pressing the yellow tab down. Other times it's ok and you can hear the relay click when you press the brake pedal.
 Check control is ok and brake lights work ok.
 Any idea what the most likely cause of the problem is guys?
 Thanks
				This happened to me as well but my brake light switch was intermittant ... sometimes the brakelights wouldnt light up and that was when it wouldnt release .... but then you say your brakelights are fine  :-/
				Often the switch, but can be the solenoid.  Easy enought to check with a meter across the solenoid ;)
 Haven't you just removed a brake switch ?  ;)  ;)
 err, no.  Bugger my back attempting it, it will have to wait until I've recovered....
 It's not the most comfortable or elegant position you need to get into to get to the switch  ;) ;D
 A useless student is over later to lift front seats out.  While he's there......  ;)
 Even you'd be able to lie down to do the job if the seat's been removed.  ::)  :y  :y
 Are you being towed somewhere then Jamie?
				Pesky brake switch out, at last.  Had to take the dash out to get the little barsteward out  >:(
				is the solenoid the bit where the yellow tab connects too? if it is then mine has gone and am wondering how on earth you can actually take it out?
				(http://theboy.omegaowners.com/oofpics/odds/solenoid.JPG)
				thanks TB, now how do you get it out?
				thanks TB, now how do you get it out? Would need to look again, but would have thought it was obvious with leather gaitor out of way  :-/
 I'll get a better pic next time I go out to car :y
				you won't believe this...
 ...the little sod is welded in :o :o :o
 Somebody here has recently changed his after  a new brake light switch didn't sort his problem
				oh bother  :o looks like I'm just going to twist that plastic bit out of the way ;D
