Omega Help Area => Omega Electrical and Audio Help => Topic started by: miggy on 02 May 2010, 21:23:45
Title: Alarm activation help
Post by: miggy on 02 May 2010, 21:23:45
Could anyone explain why when i disconnect the negative from the battery the alarm sounds?? I need to disconnect the battery to carry out some mods on a CDX and de-activate the air bags.
I would have thought that when i disconnect the negative this would make the car dead, or do i need to disconnect both negative and positive to stop the alarm sounding.
Any advice please.  :-/ :-/
Title: Re: Alarm activation help
Post by: Welung666 on 02 May 2010, 21:31:20
That is the powersounder working as it should... Easiest way is:-
1) loosen the bolt on the negative terminal.
2) switch the ignition on to red lights and turn back off again.
3) remove the negative terminal within 15 seconds of turning the ignition off.
That'll stop it screaming at you :y
Post by: charlie on 02 May 2010, 21:32:02
You need to take off battery terminal,no lmore than 15seconds after the ingition as been turn off.or the alarm will sound hth. :y :y :y
Post by: miggy on 02 May 2010, 22:01:09
Thanks for that peoples.
 :y :y :y :y
