Omega Help Area => Omega Electrical and Audio Help => Topic started by: I_want_an_Omega on 04 May 2010, 16:46:19
Title: MAF & Air Temp Connectors
Post by: I_want_an_Omega on 04 May 2010, 16:46:19
I'm having a dense moment.
I cant see how to unclip the connectors from the MAF and Air Temp sensors. I can see that there is a tab to undo - but cant work out how to undo it :-/
HELP >...........
Title: Re: MAF & Air Temp Connectors
Post by: Welung666 on 04 May 2010, 18:19:48
IIRC one has a single metal bar you push in towards the plug which releases the clips and the other has a metal V either side that you squeeze and pul. The V ones can be very tight though ;)
Post by: I_want_an_Omega on 04 May 2010, 18:33:58
Ta
Post by: John Lewis on 04 May 2010, 18:56:46
Keep pushing the little tab on the MAF plug with the two lines on with your strongest thumb and wiggle a bit using other hand on the two edges that look like clips - it will eventually click and come straight off, once you did it once it will get easier.
