Omega Help Area => Omega Electrical and Audio Help => Topic started by: Will B on 04 May 2010, 22:15:52
Title: Facelift boot release not working
Post by: Will B on 04 May 2010, 22:15:52
Hi all
Without actually removing the whole unit and doing voltage checks are there any quick checks I should rule out?
Now the boot release still works from key fob's just not from dash so I know it works I just want to get her all working as she should :y
thanks
Title: Re: Facelift boot release not working
Post by: Lizzie_Zoom on 04 May 2010, 22:36:01
Hi all
thanks
Are you trying to open the boot with the engine running / keys in ignition?  Because if you are it wont work! ;) ;)
Post by: Will B on 05 May 2010, 08:42:35
Hi all
thanks
Not sure if I tried with engine off or on lol :-? but thanks for the heads up :y
Post by: duggs on 05 May 2010, 13:16:54
IF you are, there is a little mod you can do to sort this out. Worked for me last week.
Let us know !
Post by: TheBoy on 05 May 2010, 21:28:33
Up to 2001, key needs to be removed from ign to open boot.  Post 2001, you need to press and hold button for 2s, whether keys in or not
Post by: Lizzie_Zoom on 05 May 2010, 22:07:59
Here we go again TB! ::) ::) ;D ;D ;D ;D..................My 2000 F/L does that, but usually on 3 seconds, and it has not been modified! ;) ;)
Post by: TheBoy on 05 May 2010, 22:14:28
/Panto mode...
Oh yes it has
/Panto mode off
;D
Post by: Lizzie_Zoom on 05 May 2010, 22:19:30
/Panto mode...
Oh yes it has
/Panto mode off
;D
I will prove it as agreed TB, one way or another! ;D ;D ;D ;D ;)
Post by: TheBoy on 05 May 2010, 22:23:01
/Panto mode...
Oh yes it has
/Panto mode off
;D
In your case LZ, I reckon either someone has added some extra electronics (easy-ish) or its had a new ECU.
In the meantime, PM me your reg and I'll use that to try to work out what should be in there :y
Post by: Lizzie_Zoom on 05 May 2010, 22:26:01
/Panto mode...
Oh yes it has
/Panto mode off
;D
Done :y :y
Post by: TheBoy on 05 May 2010, 22:41:49
/Panto mode...
Oh yes it has
/Panto mode off
;D
Done :y :y
I refer to my previous comment - "Oh yes it is" ;D ;D ;D
Post by: Lizzie_Zoom on 05 May 2010, 22:49:39
/Panto mode...
Oh yes it has
/Panto mode off
;D
Done :y :y
Ok, OK!! ::) ::)  So my alarm has apparently been given a later model ECU ::) ::) ;D ;D ;D ;D ;D ;)
Just shows how many variants there are of our miggies and how the advice we give to others must take that into account ;) ;)
Post by: Will B on 06 May 2010, 12:50:46
Yeah it must of been cos I had the key in the ignition as it works fine once removed ::)
sorry lol
Post by: oceansoul on 06 May 2010, 19:03:54
Let us know !
Info please?
Post by: Tonka. on 06 May 2010, 19:26:05
Here you go - - - - > http://www.omegaowners.com/forum/YaBB.pl?num=1155211091  :y
