		Omega Help Area => Omega Electrical and Audio Help => Topic started by: Raymond on 11 May 2010, 19:49:38
				I have noticed that a couple of my instrument panel bulbs have gone. Can anyone advise what kind of bulb to use? Are the high power led's any good for this? and is removal of the panel the same as the prefacelift?
Thanks in anticipation!
				Guide in maint guides section.
LEDs don't work well
				(http://i190.photobucket.com/albums/z257/belisensis/OMEGAFORUM/caplessbulb.jpg)
(http://i190.photobucket.com/albums/z257/belisensis/OMEGAFORUM/caplessbulbinholder.jpg)
501 capless. Ideally 3W
				Thanks guys, I saw the removal guide, cheers for that. So do I just buy the bulbs or do I need the bases for them as well?
Once again thanks for the info
				Sorry forgot to ask how many bulbs there are, and are they all white?
				4 bulbs, all clear. You just need the bulbs, they pull out of the base
(http://i190.photobucket.com/albums/z257/belisensis/OMEGAFORUM/Rearofinstrumentpanel.jpg)
				Cheers once again but how does only 4 bulbs light up all the different lights, i.e. engine management, oil pressure, dipped lights etc.
				What actual bulbs are blown. I assumed you meant the main illumination bulbs :question
It's four lamps for the back light illumination.
Each warning lamp has its own bulb/lamp! (not all spaces have a lamp ie seatbelt & over temp cats)
				Sorry my fault, its the dipped headlight bulb and another I cant remember at the moment but if I am in there I might as well change them all.
				Warning lamps are soldered into their holders. Orange bases are 1.2w others are 2.0w
(http://i190.photobucket.com/albums/z257/belisensis/OMEGAFORUM/dashwarningbulb.jpg)
Dipped head light? :-? There's a blue main beam ......  :-/  :-/  :-/
I think that`s what the OP means Andy :)
Dipped .... main ..... same thing really  ::)  ::)  ::)  ::) I hope I'm not travelling towards him!  ;)  ;)  ;)
page 12 (http://homepage.ntlworld.com/andrew.reynolds983/Manuals/Omega2002Manual.pdf)  :y
				Are the warning lamps a differnt kind of bulb?
Is there not a green dipped headlight one in the cluster? Maybe thats why I can't find it/thought the bulb had blown. My information display is very dull as well, do these have replaceable bulbs?
				Info display are 2.0w
(http://i190.photobucket.com/albums/z257/belisensis/OMEGAFORUM/Rearofmid.jpg)
Thats front fogs mate  ;)
You're right! Another case of Please read the manual  :y  :y  :y
Answered in my replies :y
And you just happened to have detailed photo's of these lamps & the back of the MID 'just in case'  ;D  ;D  ;D  ;D  :y
Always got Photobucket open on another tab Andy, "just in case" 8-) 8-) ;D
				Thanks for the help guys, off to look for some new bulbs now.
http://www.autobulbsdirect.co.uk/R509TMGR-Dashboard-Bulbs-12V-2.0W-Light-Green.html
RobG - Is this the kind for the warning lights, info display?
				Yep, they fit. If the company don`t do the 1.2w for the other warning lights you can get away with the 2`s
				They do them, I just used that to see if it was the correct fitting. Thanks again Rob. Thats the weekend project sorted seeing as the footie has finished.
				 :y :y :y
