		Omega Help Area => Omega Electrical and Audio Help => Topic started by: shaggydog on 14 May 2010, 16:10:18
				Hi i've got a ccr2006 and the reception is lousy, I can barely pick up local radio stations. Any help thanks >:(
				Is the roof ariel still there?
				Check the angled aerial connector at the rear of the radio - centre core is prone to fracture
 Also, if you have a screen aerial, worth checking the joints from aerial booster to screen
 If you have an external aerial, check that the internal amp in the base has not got water damaged.
				will do when it stops raining thanks :)
