Omega Help Area => Omega Electrical and Audio Help => Topic started by: Lesopc on 30 July 2010, 18:44:08
Will it be easy to remove and refit a reverse lamp switch to my 5spd manual g/box as i am not sure where on the box to find itor it's ease of access. Just to confirm that this is the fault, the car sporadically shows/doesn't show reversing lights when reverse gear is selected?????
Very rarely fail but the switch is on the prop end of the gearbox near the output shaft on the passenger side. You could "short" out the wires to confirm whether it`s the switch.
22mm offset ring spanner to remove or you may be able to undo it with small grips
