		Omega Help Area => Omega Electrical and Audio Help => Topic started by: MrTuco on 02 August 2010, 21:44:47
				Hi, I have an S reg 2.5 Elite with the CDR 500 radio, I am installing a Nokia CK-20W, what wire from the back of the stereo is the mute for when the phone rings please?
				Do you have the stubby aeriel on the rear of your car assuming it's a saloon?
 If so remove the glove box and there should be a plug with all the phone connections stuck up which you can get an adapter to plug straight into the bluetooth kit.
				CDR500 should have a label on the top showing the pin locations - its on the lower power block above the ignition live feed.
 There was a good link somewhere to the ISO pinouts, can anyone remember where it is?
 Where do I get this adapter from & what is it called please?
