Omega Help Area => Omega Electrical and Audio Help => Topic started by: markspark on 04 August 2010, 15:39:00
Hi all I’m having a problem with the interior light in the front not working the rear ones are fine the map reading lamps in the front are also. The problem is when I open any of the front doors the interior light don’t light up, when I pull out the exterior light switch as you do to turn on the interior light it still doesn’t light up, but when I lock and unlock the doors it does so this rules out the bulb being faulty so now I’m stumped as to what the problem is
TIA
Have you tried swapping out the door switches from back to front thus eliminating a faulty one :question
Not done that no but i have took the switch wire direct to earth as thats all the switch does
