		Omega Help Area => Omega Electrical and Audio Help => Topic started by: Impact Pete on 07 October 2010, 16:29:16
				Hi I'm sure a few times I have spotted that someone repairs them cheap.
 I only have the one, the top buttons are worn through and the circuit board has sheared from battery mount, it is wedged together to keep it working but sometimes the car just unlocks even when you just move the key fob about.(me thinks that is because of the cardboard tho that keeps the battery on the circuit board) ;)
				Martin Imber send him a PM
 Thank you  :)
				you can also get replacement fobs and the key blade on Ebay with the transponder chip the guy will cut the key if you provide the key code  :y was a bit concerned about this but his feedback to sales ratio is very good so .... :-/ and of course one of the guys on here could then code it for you with a tach2 i think and would save you sending the only key you have to martin , until you get the other key sorted  :y :y
 sorted thanks, kept the key part which has no issue and sent fob off to Martin, can still use car fine just got to make sure I don't loose the chip! ::)
