Omega Help Area => Omega Electrical and Audio Help => Topic started by: mr ICE man on 26 October 2010, 18:19:20
Title: New radio won't come on,help!
Post by: mr ICE man on 26 October 2010, 18:19:20
I've removed my Bose system,wiring and speakers etc,have wired all the speakers up via looping them,plugged new head unit in and nothing comes on!do I need to loop power supply too?if so which wires??I've looked in Haynes but can't make head nor tale!i checked all the fuses and they all ok.so if someone could help
I would be very greatfull!
Title: Re: New radio won't come on,help!
Post by: TheBoy on 26 October 2010, 19:53:39
I take it mr ICE man isn't good at ICE ;D ;D ;D
Vauxhalls tend to swap the 12V and Ign feeds, so this would be my first port of call....
Post by: Welung666 on 26 October 2010, 20:00:57
Only in his G&T ;D ;D ;D
[edit]to add - radio won't power up on ign number 1, must be red lights or running ;) :y[/edit]
Post by: mr ICE man on 26 October 2010, 20:32:05
How very dare you!thought that was only French cars?!my bad!
Will try it in the morning
I used to do this for a job too!FAIL!
Post by: dbug on 27 October 2010, 08:25:36
 :o :o ;)
Post by: tunnie on 27 October 2010, 11:59:50
Yeah you need to swap the feed, most headunits come with swapable feeds already wired in. I had to swap the yellow and red wires....
Post by: Phil on 27 October 2010, 13:17:28
But all you 'overnight ICE experts' appear to have missed the point.
From previous experience with Sony head units it still powered up with red to red and yellow to yellow, just didn't hold memory when the ignition was turned off.
So swapping the wires possibly will not change anything
I personally would check to see if you have a live to the plug with a multi meter (should be a permenant live with ignition off as well as live with ignition on) before going anywhere else with it.
But thats just my 2p
Post by: mr ICE man on 27 October 2010, 15:29:41
Thought I would do the sensible thing and try the old ccr700 and that all works fine,just the new stereo,a jvc won't come on!tried swapping the two feeds and fuses just in case!only option is that the stereo is buggery!unless anyone else has a suggestion??
Post by: Dave DND on 27 October 2010, 15:31:05
I must admit, I was waiting to see who was awake enough to spot that one !!
OP suggested a dead radio, not one that wasn`t holding its presets
Post by: Dave DND on 27 October 2010, 15:39:31
Run a cable to the outer chassis of the JVC stereo and earth it out to the body - does it switch on?
Blown earth track ?
Post by: mr ICE man on 27 October 2010, 17:58:48
Big thanks to save dns!was a blown track and now all fitted and working great!
Post by: Andy B on 27 October 2010, 18:09:55
Is this a pseudonym ?  ::) ::) ;D :y
Post by: Dave DND on 27 October 2010, 22:55:27
Hey - Been called worse !!
 :P
Shame on you Mr ICE Man, you should have known that JVC stereos always come out of the box with blown earth tracks !!
Post by: TheBoy on 28 October 2010, 18:50:20
 :P
Is that the same as those crap Sony Xplodes that always have Sammy Sledgehammer poking out the top after I've seen it.....
Post by: Dave DND on 28 October 2010, 18:59:35
 :P
No, Unlike the Sony crap, some of the JVC`s are worth repairing
Post by: TheBoy on 28 October 2010, 19:04:18
 :P
You're probably right...
...its just all the ones I see in Omegas look a bit chavvy, and more suited to Novas....
...but then I'm just old
