Omega Help Area => Omega Electrical and Audio Help => Topic started by: steve66 on 15 December 2010, 06:14:49
We have a similar problem with our radio CCRT 700 only it says safe and we have tried all methods to put the code in and it won't work, all were working b4 a battery change,now it won't even respond, please help
Ignition on
Switch radio off with the OI key
Press & hold AS key
Switch on radio, keep AS pressed till you hear a beep
The display shows ''CODE'' for approx 3 secs
Then ''Radio code:'' and the number of remaining attempts appear, eg ''---- <10>''
Enter code with number keys
Confirm 'OK'' by pressing the multifunction button (ie main volume)
SAFE with no number means ignition was not turned on first !!
Switch On Ignition (No Need To Start Engine)
Turn Off Stereo
Press & Hold Preset " AS " and
Switch Radio On - Display Shows
" SAFE " And Then Shows " 10 - - - - "
Enter CODE in the order it is read - eg:
For Example, To Enter Code 1234
Press Preset 1 then 2 then 3 then 4
If the correct code number is now shown
Press & Hold Preset " AS " Until the Unit Beeps
Turn Off Stereo
must be from a different user manual than mine then ;)
Turn Off Stereo
more likely a different version of CCRT700 !!
Never seen a manual, we usually write it down from what we see on the bench
Thanks for your Help but it doesn't come up with code and it doesn't beep not sure if the AS button is working as it doesn't Beep maybe need a new panel???
If you radio is not showing anything on the display, then its not actually asking for a code - YET !
Your problem is more serious than just a code - it sounds as if something is faulty somewhere
The radio display is lit it just says safe
and you've definitely got the ignition switched on? :-/
PS The removable panel is coded to the unit. ;)
SAFE on its own with no other numbers means that ignition was not turned on first BEFORE the radio
This is so frutrating the radio doesn't work on the Battery alone so it is definately off with out the ignition not sure if this helps but it has onstar as well ::) :(
turn ignition on ..... leave it on & then turn radio off with the IO button as in the instructions above.
then follow above instructions to enter code.
Onstar isn't used in Europe. ;)
If nothing comes on without the ignition, check the powers at the rear of the radio -suspect you may have lost the permenent live then.
