Omega Help Area => Omega Electrical and Audio Help => Topic started by: Clarkey on 08 January 2011, 16:11:36
Title: Sunroof Gremlin
Post by: Clarkey on 08 January 2011, 16:11:36
My sunroof has developed a mind of its own. It opens itself a fraction on tilt and then closes itself. It could do it 3 times in a row and then not do it again for days. I have reset the pinch guard on the motor but it didn't help. I think a fault in the switch is the problem. Is there any cure for this other than a new motor/switch assy.
Title: Re: Sunroof Gremlin
Post by: RobG on 08 January 2011, 16:14:49
You could try this http://www.omegaowners.com/forum/YaBB.pl?num=1247486519
Post by: Clarkey on 08 January 2011, 16:30:08
I will try that. Thank you. :y
Post by: duggs on 09 January 2011, 19:25:27
Join the club.....most if not all of us have the same gremlins.
Post by: Lazydocker on 10 January 2011, 00:01:13
Yep... Mine does it occasionally too. I rarely use the sunroof as I tend to let the Climate Control do its job so it seems to have stopped now :y
Post by: Boditza on 10 January 2011, 06:28:44
it tends to do this because of the ice forming around it. mine did this last week when the ice on the roof melted and in the evening it froze again. i fixed it by resetting it. from full close go to full tilt, the press the knob to close it. now go to full open then hold the knob to close it. hope this will help :)
