		Omega Help Area => Omega Electrical and Audio Help => Topic started by: I_want_an_Omega on 02 April 2011, 12:00:36
				Simple question ............
 Can you/how do you change a non-Bose one to Bose, or vica versa?
 Thanks - Rob
				Not a definative answer, but just my observations.
 Tech2 is virtually always needed to reprogram the state of teh head unit from Bose to Non-Bose - it CAN be done without, but very complex and the procedure is best avoided.
 If a head unit has BOSE screen printed onto the front somewhere, then it is unlikely to be able to be reconfigured to Non-BOSE useage.
 If the head unit is a standard one, then there is a 75% chance of toggling between Bose and Non-Bose - but I am unable to define which versions can and cannot be done, its a trial and error one I`m afraid.
				Thanks Dave,
 Luckily my "spare" one is non-Bose  - but I may need to press it into service.
 What's "the worse that can happen" if it isn't converted before I swap it over?
 Cheers
				It will work, but volume will be errattic and a little uncontrollable, but not the end of the world - you may not achieve the desired volume, and I know you are too sensible to run it at full volume, as that would certainly cause some issues.
 no no no no no no ........  :o
 point taken & thanks
				AFAIK, all ccrt700 units can be set to Bose or non-Bose, its done via Tech2, as is the country coding.
 As long as it's not one of those pesky CCRT700's that cause coms trouble with the Tech 2 (like mine) ::) ::) ;) ;)
