Omega Help Area => Omega Electrical and Audio Help => Topic started by: albitz on 27 April 2011, 10:07:08
Title: HID stopped working.
Post by: albitz on 27 April 2011, 10:07:08
Fitted a pair of HID,s from my breaker onto my own car last week. Noticed last night that one of them has stopped working.
The sidelight and main beam are ok. I have checked the connections where I spliced the wires and they are fine.
Maybe moving the unit around has fubared the bulb ?
Hope not as istr they are mega expensive.
Happened around the same time as my LPG went down, but I doubt they are connected.
Title: Re: HID stopped working.
Post by: RobG on 27 April 2011, 10:10:48
N/S fuse #22..........O/S  fuse #31
Post by: albitz on 27 April 2011, 10:33:11
Good point Rob, hadnt thought of that. :-[ ::)
Post by: albitz on 27 April 2011, 10:56:54
Found fuse 31 to be blown. replaced it and it immediately blew again, so a problem needs found and solved. :-/
Post by: albitz on 27 April 2011, 13:06:17
Anyone know of anyissues which would cause shorting/blown fuses ?
Post by: CaptainZok on 27 April 2011, 13:29:20
You've not really got the hang of this electrician lark yet have you? ;D
Have you got any wiring that's rubbing on the bodywork, exposed copper will do it every time.
Might be worth taking that light out again and having a good check of the cable.
Post by: albitz on 27 April 2011, 13:50:37
I checked where I had spliced into the loom and that was fine. Will have to delve a bit deeper - when I can find the time. Busy as break at the moment. :y
Post by: CaptainZok on 27 April 2011, 13:53:29
Cover fuse in tinfoil, replace, wait till after dark, switch on headlights and look for sparks seemples. ;D ;D ;D
Post by: albitz on 27 April 2011, 14:45:53
That,ll work. :y ::) ;D
Post by: Kevin Wood on 27 April 2011, 14:46:23
.. and have a few steaks ready to lob on the bonnet if it's a real proper short. ;D
Post by: Lazydocker on 27 April 2011, 16:47:28
Afraid Albs, I would guess that your wiring is at fault somewhere :-X :-X ::) ::)
Post by: Humpy on 27 April 2011, 20:13:31
I had to up the fuses to 15A as the standard 10A fuses sometimes blew when I switched the headlights on. I think I'm right in saying the Facelifts with HIDs have bigger fuses too???
Humpy
Post by: albitz on 28 April 2011, 19:53:18
Had a look at the fuse box (which seems to have colour coded sockets and that one is blue. Put a (blue) 15amp fuse in and it seems fine now. Thanks for that humpy.
Interestingly, I was on my way to work on the bike today and my speedo/rev counter/ water temp guage and indicators went down. Got to work and checked and lo and behold - a blown fuse. Havent had a blown fuse for years and now 3 in one week. ::)
Post by: RobG on 28 April 2011, 20:39:28
What about the one in your brain ;D ;D ;D ;D
Post by: albitz on 28 April 2011, 20:49:26
At least I have a brain. :P :D ;D
Post by: CaptainZok on 28 April 2011, 21:08:10
Did the tinfoil trick work then? ;D ;D
