		Omega Help Area => Omega Electrical and Audio Help => Topic started by: albitz on 06 June 2011, 20:44:06
				Three wires which come from the multiplug at the rear of the headunit-
 Black -labelled as mute on the diagram
 Blue labelled as TL+ on the fdiagram
 Brown - labelled as TL- on the diagram
 They dont go to the main Bose loom but go into the main loom towards the n/s of the car. They have been chopped when I was removing some other component. Any chance they might be connected the the lack of any sound from the system ?
 Tia.
				suspect they went to prewiring for phone.
 No, wont affect it, unless the mute is shorting down, thus giving 'External Audio' on CID
 ......... you wish Albs ;D ;D
				I think I will now probably have to accept that its got a problem that Im not going to solve. :(
 I would at least liketo know if its the headunit or the amp. :-/
				Has LD got a 2013 in his new baby :question
				Now theres a thought. ;) :) ::) :-X
				You won`t get nowt on his display but I would have thought if your HU is OK you should get sound, unless someone posts to the contrary ::) :D
				yes, you will get radio, along with annoying bleeps every 5s
				yes, you will get radio, along with annoying bleeps every 5s That`ll be Albs cursing ;D ;D
				Is the amp getting power? Amp is seperate fuse to HU
				Know which fuse ?
 I would have thought it would maybe be easier to try "an other " amp plugged into my headunit rather than swap headunits over ?.......if the amp is from an estate that is ? :-/ ;)
				Have you checked fuse #6
				I think so, will look again in the morning.
