Omega Help Area => Omega Electrical and Audio Help => Topic started by: twiglet on 19 June 2011, 23:12:26
Evening all!
My Omega currently has a NCDC2013 HU with GPS and GID. I'm about to swap this over for a NCDC2015 with CID & Telematics. Just a few questions....
1. Do I need to put anything into delivery mode prior to removing the parts, or is that not necessary as I am changing the whole system?
2. Do I have to install any additional looms (for telematics, CID, microphone, etc)?
3. Where is the telematics microphone (on the HU or up on the interior light)?
4. Which mobile networks does the telematics work on?
While I'm at it, I believe that the right-angled gps connector on the cage of the car the 2015 system is coming out of has been damaged...
1. Is the OOf recommended fix for this still to adapt the cage and fit an aftermarket gps antenna? Or has anyone come up with another solution?
2. Is there a method of ensuring this connector doesn't get broken when sliding the HU home?
I think that's enough questions for now...
TIA :y
1 if it's all paired and original from the previous car, no! It's already done.
2 yes, there is no loom for telemstics in a 2013 car
3 You'll have to fit one in interior light.
4 02 or voda only... Not sure if one of their affiliates will? Guessing not.
Pass on the last 2.
1) No - as long as all parts remain together.
2) Yes - easiest to modify an Traffic Master loom rather than butcher the car loom. Some bits can be got from the phone prewiring, but not all.
3) Conference Mic is its full name, sits in interior light.
4) Any 900Mhz GSM - thats O2 and Voda, plus the networks that run on these, such as Tesco Mobile, and my own personal favourite, GiffGaff (which is what I use in my Telematics). If going for the latter, if you sign up using my referral link, you get an extra £5 credit with your first £10 top-up. http://giffgaff.com/orders/affiliate/theboy
GPS connector.
1) Never found the correct plug that can clip in to cage. When I retrofit NCDC, I use a cheap receiver with the (electrically) correct plug, which I plug in to back of HU before pushing HU back in place, at same time gentley pulling the slack from the cable via one of the footwells. I can dig out the egay auction for them if thats a route you want to go down.
2) Original connector? Ensure cage isn't distorted, that the connector firmly clips in place.
Cheers Chris and TB for you usual speedy responses! :y
I'm actually buying the complete car with the 2015 system in so, parts wise, I should have everything I need.
is the telematics loom a separate plug-in loom that just runs from the telematics unit to the HU, or is it actually part of the main wiring harness (in which case I assume it's best to swap over the entire harness, if possible)???
I'm sure it will become clearer once I have the cars together and start taking the apart, but it's nice to have an idea what I'll be facing! :-/
GPS connector.
1) Never found the correct plug that can clip in to cage. When I retrofit NCDC, I use a cheap receiver with the (electrically) correct plug, which I plug in to back of HU before pushing HU back in place, at same time gentley pulling the slack from the cable via one of the footwells. I can dig out the egay auction for them if thats a route you want to go down.2) Original connector? Ensure cage isn't distorted, that the connector firmly clips in place.
Is it this one? http://cgi.ebay.co.uk/SMB-Male-GPS-Antenna-Active-Amplifier-2M-Cable-/230526593445?pt=UK_CE_GPS_Accessories_Software_ET&hash=item35ac74a9a5
Its a different dash loom, you stand precise no chance of unpicking that ;D
But, if you're breaking the car, which I suspect you are if its the one I think it is, you'll have plenty of scope to get the required plugs and have access to plenty of bits of wire. See Lazydockers thread about telematics, as it shows how to fit in via TrafficMaster loom
GPS connector.
Thats the very one, from the same company (assuming its SMB Male - I always get confused between NCDC and CARiN, one is male, other is female) :y
Sorry if I'm being a bit thick, but can you explain a bit more please?
Yes I do plan to break the car (and I'm sure it is the one you think it is). I've been reading LD's thread, but from what I can tell he already has telematics as standard. It's quite a long thread now, so maybe I'm missing the important bit that's relevant. As far as I know, neither car has TrafficMaster installed, but I assume from what you're saying is the TM loom will be there anyway?
Confused.com... :-/
Confused.com... :-/
You won't have the TM loom already, you need to get one. What he's saying is that the TM Loom is the best place to make connections required as then you minimise the damage to the car loom and also you can do it on the bench ;) :y
I might have to come up and look at this breaker... There's a few annoying little plastic clips I need ::) ::)
...........and if you need a TM loom ::)http://www.omegaowners.com/forum/YaBB.pl?num=1308163185
Rob, can you hold that for me please? I'll be able to confirm that I need it very soon. :y
Confused.com... :-/
I'll give you a shout when it arrives then... ;) But only if you help me install my telematics... :y
But he has to come to me first for some other clips and bitz (and help me install "My Naff Code Reader" software and have a look at my Bose unit.) :P :D ;D
Consider it done :y
I shall form an orderly queue then! :P
Must be nice to be so popular, hey Paul! ;)
Paul`s a decent chap, it`s just that Albs is a tad stupid `cause his "brain hurts" ;D ;D ;D
You can fack orft - geekfreek. :P ;D ;D
Get on your horse & cart and start selling your old tat :P
Now now children, play nicely! ;D :y
Evening all!
TIA :y
Some people have fists of ham :-[
I fitted an an aftermarket gps antenna?, then ran this up to the window on the pass' side, worked very well.
Car is now broken (gone to the car park in the sky), but I removed all the bits - NCDC2015+CID and aftermarket gps - you can push the unit home and feed the cable slowly - watch your hands, as they can get sliced putting the cable in at first. :y
if you need any bits just send us pm, as need to shift em. (got no loom or tele bits - just re-wired to make fit my cd estate)
I need a NCDC2015 for a moment now... ::)
Ok, I'm making progress installing this into my car. I have fitted the CID and the 2015, primarily to test the functionality of the GPS, which all seems to be working as it should!! I have however discovered that the 2015 unit I am installing is not Bose enabled, so its a tad on the loud side!! :o
Is anyone going to Billing with a TechII by chance, or likely to be in the Suffolk area anytime soon? :y
I'm getting stuck into building up my telematics/TM sub-loom, whcih I think I have got my head around! The only thing I need now is to remove the section of coax aerial that runs from the telematics unit to the drivers kick panel. This look to be sewn into the main loom!! :o
Has anyone had to remove this cable? If so, is it best to completely remove the dashboard to gain access? Which route does it take from behind the glovebox to the drivers kick panel?
Also, what is the best route for the TM loom and coax lead when I come to run them in my car?
TIA, Twiggy! :y
I'm about 30m the wrong side of Billing.
Telematics loom - obvious, straight out.
Aerial, runs in the main bulk of wire from behind stereo, by steering column, down into kickpanel. Unpick, but it will be a pig.
I'd rerun the same way
Thanks Jaime. :y
I take it you're not planning on going to the show then? If not, I'm wondering if you could spare me a few minutes at some point over the weekend? :-/
Thanks Jaime. :y
I have no spare time to make Billing, too much to do before the Lakes :'(
If I'm in, I can do that, but will need to know approx time first to ensure I can be in
Thanks Jaime. :y
PM Sent :y
