		Omega Help Area => Omega Electrical and Audio Help => Topic started by: Adies08 on 02 August 2011, 19:51:41
				Hi does anyone know anything about the CCRT2008 radio. It says in the manual to use the phone in it you need a registered sim card with your customer id on ???? Where would i get one of these ?? Cheers
 basically if it is the same as a ccrt 700 all you need is an o2 or vodaphone pay as you go sim then away you go  :y
				ok cheers mate. If my omega was fitted with a ccr 2006 will it have all the relevant parts to run the ccrt 2008 ?
				Nope. Need a CCRT MID and wiring mods to the loom, so would be easier to source a TM 36 way ISO connector to modify
 So you might as well go the whole hog and fit a NCDC2015 with Telematics and CID  :y
				Easy enough conversion, but you need wiring diagrams for both ;)
 Ccrt2008 is similar to ccrt700 in prefacelifts, though only 4 disc changer
