		Omega Help Area => Omega Electrical and Audio Help => Topic started by: plumbob on 11 August 2011, 12:38:02
				Hi all thanks for suggestions from previous posting,but could somone please tell me if this unit is a straight swop for a 2005?. I've noticed some suggesting it is,but I'm not getting any display from the radio,i turn it on with AS pressed in and hear the beep but no display.Are the display connections the same?Haynes manual shows the same connections?help!!!
				Straight swap. No lights on radio or nothing showing on the MID :question
				Straight swap -
 Did the display work correctly on the previous radio?
 Check all plugs are firmly in place
				hi thanks for replys,yes display was fine on the old radio. The lights come on when i turn it on,the time/date goes and nothing?
				Are the multi-plugs still held firm in the rear of the cage
				Hi Robg I hav'nt had time to check yet got to get 3yr old to bed i'm going to have a look in about 1/2 hour cheers
				hi Robg spot on,the top multi plug had a clip holding it in broken so was only half connecting,pushed it in and off we went.Thanks a lot cheers.
				hi Robg spot on,the top multi plug had a clip holding it in broken so was only half connecting,pushed it in and off we went.Thanks a lot cheers.   Easy fix then :y
