Chat Area => General Discussion Area => Topic started by: RolandL on 27 February 2008, 21:00:10
Hi Guys n Gals, just posted new How2 in maintenance are :)
:y :y :y good job done
Nice one .. clearly written with good piccies
:) :y :y
Cheers
Brill! :y
Great how-to; `already had a numpty Kwik-Fit fitter crack my metal housing (mercifully a scrap yard replacement unit rescued me) so this job is def. on my to-do list (after fitting cruise) ;)
Only one query: the threaded-nipple (adaptor); is that a Vx part No or another supplier?
Brill! :y
You can get the threaded part from Vx (not to expensive)
Does your CDx not have cruise control?
No cruise on my `99 CDX (oddly) :'(
I`ve bought a cruise-stalk from forum member Chris, but I`m still looking for a cruise-actuator to complete the job....please, anyone?
What do you use to tighten the adaptor? Suggested torque?
I'm going to do mine ASAP.
Excelent 'How to' :y
Been down to the Vx Dealer today and ordered the treaded nipple; `not a stock item there but `should have it in a day or two (£3.51 +VAT); `gonna pick up a couple of spin-on oil filters and a 3 for 4 pack of semi-synthetic oil when I go back to pick it up; then I`ll be sorted for all my summer cruisin`. :y
At the parts counter, I mentioned the the reason I knew the P/N for the nipple was the 'How-to' on O.O.F: then the parts-manager instantly said "oh it`ll be on T.C terms then!"....Our reputation has travelled-far it seems! ;)
Great "how to", :y
I actualy like the paper oil flters.....but, no heavy handed mechanic ever gets near my cars!
Ow yes, I would start with 45Nm torque setting as thats what the housing attaches at and its the same thread etc...
I agree Mark, at least you can give the old filter and housing a good inspection to see if there are any forgien bodys in there that shouldn't be as this is a good indicator of engine wear or something starting to break down, just my opinion for what it's worth ::)
Deb - go for the 4 for 3 deal instead - much better value :y
[size=8]sorry![/size]
:-[.......oh much better value! Hahahaha! ;D ;D ;D ;D ;D ;D ;D ;D
*Thinks: I`ll make a pental most it note to engage brain in future before typing! :y
Which dealer do you use? Lookers at Deeside?
Why????
They cost more, and take a little longer to change. :-/
Slaters at Colwyn Bay; `just right next to the West-bound A-55.....the parts-counter staff always seem approachable and helpful, and I don`t feel patronised (or 'unduly' overcharged).
Where I live (in the mountains of Southern Snowdonia) all the big-dealerships are a 45 mile round-trip away. ::)
Passed it many times when we head out that way.
thought you were nearer this way than that.
With that distance, youve gotta stock up when you go!
Excellent how too - i actually used this conversion for the vectra v6 prior to the how too as i couldnt get the metal hosing off.
I do have a slight oil leak ( a drip) from housing/ filter since but i didnt use locking lotion.
Never mind the Vectras getting its sump off, due to low oil pressure, next week so no harm in re doing the filter and obviously an oil change too.
The StudLocks act like a "glue". Have a look at the following it'll make more sense.
Pay attention now, I'll be asking questions later ;D ;D ;D
RiteLok anaerobic adhesives are high performance, single component engineering adhesives, that cure in the absence of air and in the presence of metal parts. RiteLok anaerobic adhesives are frequently used in assembly by original equipment manufacturers, maintenance departments, upgrade and overhaul projects and throughout the automotive and engineering sector. RiteLok anaerobic adhesives are available in a wide range of strengths and viscosities. The RiteLok anaerobic adhesives range is used for threadlocking, retaining, sealing and gasketing.
T70 Studlocker eliminates double nutting and/or welding of critical assemblies. Using T70 Studlocker permits reduced casting thickness, and ultimate lightness, reduced assembly stress and eliminates cracked castings due to interference fit
Rocol X12-70 - Studlock
>< For high strength thread locking
>< For permanently locking mounting studs into pump housings, manifold assemblies, thread inserts and engine blocks
>< Use on all types of metal threaded fasteners
>< Only use on parts that will NOT require dismantling
And this is Loctites' version
Studlock, high strength threadlock and sealing adhesive permanent strength Loctite 270 type
Grade Studlock
Generic Type High Strength
Colour Red
Viscosity (ASTM1084,1824) 400-600cP (medium)
Fixture Time 15-20 minutes
Working Time 2 hours
Full Cure 24 hours
Gap Filled 0.1mm
Specific Gravity 1.1
Flashpoint (TOC) >100°C
Corrosivity (MIL-S-22473D) None
Toxicity Low
Shelf Life (25°C) 1 year (minimum)
Locking Torque Breakaway 25nm
Prevail 35nm
Service Temperature 50°C to +150°C
Thermal Expansion 8 x 10-5 mm/°C
Hardness: ROCKWELL M110
Decomposition Temperature 252°C
as you can see, after 24hrs it would take 25nm to break the seal, after a longer period it would take upto 35nm. When you put the filter on and nip it up, it tweaks the adaptor. At the next oil change the filter will come off as it won't have "gone on" at 25-35nm.
Hope that makes sense ;)
sorry it was a bit long
Thanks. Got that.
