Chat Area => General Discussion Area => Topic started by: Stevieb on 29 February 2008, 14:43:11
Title: Cambers causing tyre wear!!
Post by: Stevieb on 29 February 2008, 14:43:11
I have had a second tyre blow out in the space of three months. Just got my second new tyre today and the garage informed me that this is common on Omega's.  It’s something to do with the cambers as the wheels are slightly tilted inwards, causing more wear on the inner wall than the rest of the tyre.  Has anyone else experienced this and what have your done to put this right??
Title: Re: Cambers causing tyre wear!!
Post by: Elite Pete on 29 February 2008, 14:46:47
Hi Steve and welcome to the forum.
I would say its because the suspension is set up wrong. Depending on where you are in the country, it would be worth a visit to Wheels in Motion to get yours set up correctly ;)
http://www.wheels-inmotion.co.uk/
Post by: bob.dent on 29 February 2008, 15:21:06
Yep, certainly have and it's a bugger to get right on mine as the wheels and tyres aren't standard. I've been to WIM for 4 wheel geometry which vastly improved it but I need to go back there for a more customised setup.
Post by: albitz on 29 February 2008, 15:27:45
i,ve never heard of blowouts being a common problem. :-/
Post by: bob.dent on 29 February 2008, 15:31:16
I don't think blowouts are some much a common problem but the uneven tyre wear can be unless the geometry is set correctly.
Post by: JamesV6CDX on 29 February 2008, 15:33:23
I expect  people glance at their tyres, think "these look ok"....
whereas in reality, if they look closer, the inner edge is on the canvas!!
Post by: albitz on 29 February 2008, 15:35:07
got me worried now ,i will have a look when it stops raining..........june probably :)
Post by: Elite Pete on 29 February 2008, 15:38:21
2010 :'(
Post by: bob.dent on 29 February 2008, 15:39:08
Spot on James, exactly what happened to me last year. Mine was down to the steel belt on the inner edge whereas the rest of the tyre looked perfectly ok!! :o
Probably would have resulted in a blowout if my mechanic hadn't of spotted it when the car was up on the ramp.
Post by: Marks DTM Calib on 29 February 2008, 15:40:24
In-correct camber will cause tyre edge wear (inner if to much camber and outer if to little).
The camber will also change as the car ages and the springs get weaker....so, get your camber set as part of a proper geometry setup and all will be good again.
Post by: Stevieb on 29 February 2008, 15:58:04
That’s exactly what my tyre was like...down to the steel belt, except I didn't spot it, hence the blow out.  Just annoying when the rest of the tyre is perfectly fine, yet the inner edge wears away, especially at the prices we all pay.... I have the big chunky low profile tyres!!!!
Post by: TheBoy on 29 February 2008, 17:06:07
Yes, I've experienced horrific inner shoulder wear on the front of my MV6, all put right by wheels-inmotion as suggested about.
Post by: Marks DTM Calib on 29 February 2008, 17:08:15
Which is why geometry checks are supposed to be a fairly regular thing!
And dont get fobbed off with tracking.....
Post by: TheBoy on 29 February 2008, 17:16:28
Couldn't agree more.  I tend to get mine fully geo'd instead of track/4 wheel alignment, and tend to do annually.  Should be more often if I let Mrs TheBoy drive  :-X
I spent a fortune on tracking and 4 wheel alignments and, despite what the tyre outlets were telling me, its a waste of money in many cases.
Both my Omegas are due, just waiting for the new WIM centre to open.
Post by: bob.dent on 29 February 2008, 17:34:06
I spoke to Tony by e-mail today and he reckons it might not be for another 3 weeks yet. :-?
Post by: TheBoy on 29 February 2008, 17:42:41
Bugger - I may need another alignment centre then. Tractor wasn't happy about hitting that speed bump that hard. It would appear shagging the tyre wasn't the only damage  :'(
Post by: Jimbob on 29 February 2008, 18:23:34
NOT AGAIN!!!!!
Post by: TheBoy on 29 February 2008, 19:03:55
NOT AGAIN!!!!!
No, Saturday's incident....
Post by: PaulW on 29 February 2008, 19:39:57
Yeah I need to get mine checked and corrected too from those little concrete death humps...
Post by: MikeDundee on 29 February 2008, 19:44:09
Stay clear of second hand tyres :y, especially if you drive on motorways, and get the geometry done as previously mentioned :y
