Omega Help Area => Omega General Help => Topic started by: marco24v on 24 September 2011, 17:30:21
Hello all. I've been to see an omega and it was a pleasure to drive. My only issue was that the steering pulled to the left for some odd reason. The car was nice with full leathers manual and fsh. Im just a bit worried about the streeing incase it leads to more trouble. The guy is keen on a swap but it has to be right or a cheap fix
Can anyone help?
cheers marc
the steering components are a bit complex on the omega, and after any worn parts are replaced you need to have a full geometry check which includes checking camber,not just the usual tracking. :y
may be worth checking the wishbones as they are a common failure on the omega ;)
Is it expensive as im trying to keep costs down if i choose to swap it
Around £80 i think for a full set up. :y
Thats not too bad. I wish I had someone to take a look so I can determine the extent of the problem. Its not major but an annoyance as I like my cars to go straight lol
checking tyre pressures and wheel balance may help :-\
There are some OOF Technicians On the forum who may be able to help. Mainly around the Central Parts of England. Darth loo Knee aka Daz (Stoke) Elite Pete (Northwich) and Welung666 (Lee in Dudley, West Mids)
I've got a mechanic but hes always busy. I beleive the car is a bargain and has loads of history etc. Just needs a tiny bit of tlc and it will be perfect.
Post your area in the proflie page, I'm sure someone will be able to look at it for you.
where in middlesborough are you i only live up the road at peterlee
Hello. Im just in Marton and the car is just down the road from me. I know its a good car deep down just wish i knew a bit more.
hi marco if you would like me to have a quick look pm your adress but i am not available untill tuesday going to my daughters in scotland for the day tommorrow :y
Hello Tony2. I got the car today. It turns out the tyre was quite flat 6psi infact. Drove it today and it it fine now. Its sat on my drive as we type. I would still like to meet fellow omega owners such as yourself though and i appreciate the offer regards
marc
hi mark glad everything turned out well, and welcome to the omega club any problems you are shure to get answeres will allways be on here. good luck and happy motoring allways welcome to keep in touch tony
glad you got it sorted and hope you enjoy driving it :y
Hello Tony2. I got the car today. It turns out the tyre was quite flat 6psi infact. Drove it today andow it it fine n. Its sat on my drive as we type. I would still like to meet fellow omega owners such as yourself though and i appreciate the offer regards
marc
Great result you can't get a cheaper fix than blowing the tyre up :y
