Omega Help Area => Omega General Help => Topic started by: albitz on 13 October 2011, 12:15:22
Title: Injector question.
Post by: albitz on 13 October 2011, 12:15:22
The brown plastic/bakalite ? washers/seals on the end of the injectors.Are they particularily important ? I have 5 of 6 missing.
Currently have a set of 3.2 injectors on the car (2.5) and the car spends most of its life running on LPG anyway.Would prefer to swap back to the original injectors if the missing bits arent going cause a problem. :-\ Are they replaceable ?  Tia.
(http://i1238.photobucket.com/albums/ff500/Albs59/DSCF1211.jpg)
(http://i1238.photobucket.com/albums/ff500/Albs59/DSCF1212.jpg)
Title: Re: Injector question.
Post by: Kevin Wood on 13 October 2011, 12:50:37
You might find the O rings get sucked off the end of the injectors and into the intake without them. :-\
Post by: albitz on 13 October 2011, 12:59:27
Good point Kevin.Do you know if they are replaceable/available ? :-\
Post by: Kevin Wood on 13 October 2011, 13:06:46
I'm sure they are but I wouldn't know where to look, TBH. :-\
Post by: TheBoy on 13 October 2011, 13:15:37
Albs - I'd normally suggest trying one of the helpful breakers on this site ;D ;D ;D
Sure Twigs/Pinky/EP etc etc can sort you one if you're not expecting one in soon yourself :y
Post by: albitz on 13 October 2011, 13:37:37
I have a perfectly good set on an engine which sits on my drive,but they are on a very sweet running low mileage engine.Dont want to start pulling bits off it. ;)
Post by: albitz on 13 October 2011, 13:39:47
Will ask Twigs though.Hadnt thought to ask him to be honest,but Im sure he will help if he can.Hes a fine young gentleman,but dont tell him I said so. ;) ;D
Post by: twiglet on 13 October 2011, 14:44:30
I've got 2 sets of 2.6 injectors here so, assuming they are the same, I'm sure we can sort something out next week.  :y
I hope I'm not breaking any rules by mentioning this in the General Help section!  :-\ :P :-X
Post by: albitz on 13 October 2011, 14:49:15
No idea if they are the same James.Hopefully someone else will know. :y
Post by: Kevin Wood on 13 October 2011, 14:56:08
IIRC, 2.6/3.2 have different injectors and a higher fuel pressure than 2.5/3.0. The question is: does this matter? If they flow at roughly the same rate and have the same electrical characteristics probably not. Does anyone have the two part numbers so I can compare specs? (It's the Bosch number - 0280 xxx xxx)
Post by: albitz on 13 October 2011, 15:01:24
Got 3.2 injectors complete with fpr etc on there at the moment.Car seems to take a bit longer to start from cold than I would expect,and I seem to use more petrol than I woud like.May not be connected though,planning on changing the plugs at the next service in a few weeks time,so that could improve the percieved problem. :-\
No idea on P/N btw,and if there is one on an injector,probablt too small for me to read. ;D
Post by: albitz on 13 October 2011, 15:07:10
No idea on P/N btw,and if there is one on an injector,probably too small for me to read. ;D
.....or perhaps not. 2.5 injectors - blue - 0 280 155 712. Below that it has A  961.
On the FPR - 3.0Bar. 0 280 160 560.
Post by: Kevin Wood on 13 October 2011, 15:11:21
Part No.Flow Lb/hFlow cc/minPSIBAR
0-280-155-71219.4203.943.53
Post by: albitz on 13 October 2011, 15:12:35
Dont mean sh1t to me Kevin. :-[ ;D
Post by: Kevin Wood on 13 October 2011, 16:02:50
It doesn't to me either, until we have the part number of the other injectors. ;)
Basically, it's flowing 203.9 cc/min at 3 BAR fuel pressure.
The 2.6/3.2 injectors work at 3.8 BAR IIRC, so the question is what is their flow rate at 3.8 BAR?
Post by: Kevin Wood on 13 October 2011, 16:31:59
According to one of steve's ebay listings :y
3.2/2.6 injectors are 0-280-156-045
0-280-156-04518.25191.843.53
So, lower flow rate @ 3 BAR but IIRC the FPR is 3.8 BAR on a 2.6/3.2 whereas the injectors are specified at 3.0 BAR. Should flow about 215cc/min at 3.8 bar. So, a bit more fuel flow but I'd expect the ECU to "learn" around that small a difference.
Post by: albitz on 13 October 2011, 17:05:07
Sounds like I might as well just leave them on there then. :-\
Post by: Kevin Wood on 13 October 2011, 17:45:30
Certainly no desperate rush to change them, IMHO.
Post by: albitz on 13 October 2011, 18:17:39
Next spring sounds like a suitable time. :y :)
Post by: bored bigyin54 on 13 October 2011, 18:22:37
if we have a spring lol
Post by: albitz on 13 October 2011, 18:27:43
True. ;) ;D
