Omega Help Area => Omega General Help => Topic started by: andycab on 13 October 2011, 15:46:43
Title: 2.2dti vacum pipes diagram
Post by: andycab on 13 October 2011, 15:46:43
Help i desperatley need diagram of vacum pipe routing on 2.2 diesel,2 garages have worked on this car and not sure if theyve put them back rite as its down on power.Car is a taxi and ive lost 4 wks work so far.
                                                            Thanks
Title: Re: 2.2dti vacum pipes diagram
Post by: otomega25 on 14 October 2011, 15:45:39
hello mate ! look here a vacuum scheme and what should you check, i 'am from Romania and i'm sorry for my bad english, i have some problems too with my omega x20dth with Y22dth soft and turbine  ::) ... help ! i want to upload image but i can not !
Post by: otomega25 on 14 October 2011, 15:58:29
solved ! i sent him a pm. i am at work and a dont have the permission to install drop box...
Post by: Bobirings on 07 August 2017, 23:35:43
Hello I know it's been a long time since your post
 Could you, if you still have it to send me also the diagram of vacuum pipe that you send to "anycab"
because I need the same thing.
Thanks in advance
Post by: raywilb on 08 August 2017, 16:11:47
                                                            Thanks
  there was a diagram on here but I cant find it now ,maybe somebody will bring the original post up.
Post by: raywilb on 08 August 2017, 16:23:09
                                                            Thanks
  there was a post by Boilerman , been looking but unable to find it.
Post by: raywilb on 08 August 2017, 16:40:51
                                                            Thanks
look at Boiler Man posts & you will find a diagram  :y
Post by: Magwheels on 08 August 2017, 19:28:09
http://www.omegaowners.com/forum/index.php?topic=125954.msg1607139#msg1607139
Post by: raywilb on 09 August 2017, 16:07:57
b  I think 9 is meant to be the turbo & 10 is I,m sure is the turbo boost valve which is hard to spot, but if you take away coolant expansion tank its in that vicinity, I,m sure one vac pipe comes off turbo to it &  other from No 10. is as drawing is.
