Trading Area => Car Parts, bits For Sale & Wanted => Topic started by: BgBLizard on 18 October 2011, 13:25:28
Hi All
If this could be moved it would really be appreciated.
I am after a exhaust manifold for my sons 2.0L facelift on a 2000W plate if any one could help.
Cheers
I've got a 2001MY 2.2 exhaust manifold here, not sure if it's the same though. Don't suppose you have a part number? :-\
Im sure it will be OK thanks :-[
you ok to post?
Twiglet
Does 2l have SAI on, if so, likely that plumbs into manifold, and doubt 2.2 has that...
Correct on both :)
We had to remove a pipe with two small connections to the manifold so that would be the SAI.
Manifold is not here at the moment so cannot check PN but asked this qustion before and got this answer
http://www.omegaowners.com/forum/index.php?topic=94072.msg1178849#msg1178849
If fitting a 2.2 manifold, strip out all the SAI system but leave the solenoid valve with it`s electrical connection in place.
Thanks Rob
Possible to use a resistor instead of solenoid to fool the ecu.
Thanks twiglet
Tried to contact you but go this "PM could not be sent to 'twiglet' as their inbox is full!"
Try again mate, just had a clear out ::)
