Omega Help Area => Omega General Help => Topic started by: Stan_2 on 28 October 2011, 20:39:25
Has anyone used Halfords Autocentre for a diagnostic check?
If so what did you think of them?
Or heard anything to put you off using them?
They charge £50 for a diagnostic check, is that reasonable?
Vaux dealer would be cheaper i think! :o
buy your own reader! :y
I use a paperclip myself. ???
i got charged £60 to get the codes read just on my auto box from a vx dealer when i broke down in cornwall :( :o
halfords autocentres, formally nationwide autocentres, will tempt you in with cheap quotes that grow massively once there. Avoid at all costs
Agree with The Boy they are absolute Clown Shoes. Put a terd in a frilly dress , its still a terd !
Ha Ha agree!!!!! ;D ;D
Thanks for the replies, I was only going to use them because they were convenient, only about 4 miles away. I’ll forget about halfords now after what TB said.
Looks like I’ll have to wait for a bit until I can book it in at the stealers.
If I could do the paperclip check I’d make a right pigs ear of it, I'd be like Del's brother, Rodney, a right plonker ;D
The airbag light is on all of the time, that doesn’t bother me at all.
It’s the emissions light on 80% of the time that’s bugging me, I don’t know if I’m making things worse while driving it.
I like that, must try to remember it. ;D
The paperclip trick is very easy!! ;) Even I can do it!! :D :y There's a 'how to' in the maintenance section. Why not give it a try? It's free!!! :y
There's also a list of codes somewhere here as well that will point you in the right direction or post up the codes and hopefully someone will tell you whats going on!! ::) 8)
No!
Hi mate, here's the link for the paperclip test and as said before, very easy to do :y
http://www.omegaowners.com/forum/index.php?topic=90581.0
HTH's
As has been said, try the paperclip test then post up the codes it flashes out. Nothing to lose and it could save you your £50.
Failing that, you could take a jaunt down the M3 and I'll take a look with the Tech 2. I'm often around the J4a area so we could meet up somewhere there.
I’ve just had a look at the paperclip link, thanks.
I’ll have a go at the paperclip test next week, I’m don’t feel very confident about getting the codes. I’ll have a go tho.
Thanks again everyone :y
Halfords....by all means go there and then you give us all a laugh when they make a B of it. They are a shop for accesorries and not mechies. However you dress a monkey it is still a monkey.
Find an oofer living locally with the gear to do it or buy a code reader cos they are cheap enough unless you want the full Tech2 job.
I bought a code reader to save the cost of the dealer stealers and it performs as it should each time I plug it in.
The problem is I very rarely have any codes flash up! ;D
Sods bloody law that ::)
They are nothing to do with Halfords, other than name
:y I know that but I have had personal experience with them before I knew DLK. In my view they rely too much on tech and not enough on practical hands on experience. I dare even go so far as to think of them as pretendy mechanics.
There again in desperate need its any port in a storm so the saying goes........ ;D
Unliklely a reader will work as it's a 2000 model, usually only 2001 onwards so would we be talking pedal trick in as it has an emmision light i.e facelift?
This is true of a large chunk of the motor repair industry, IMHO. A code reader is no use whatsoever to someone who doesn't know in detail how the system they are diagnosing works. They will assume that every fault code diagnoses a faulty component and so the process of replacing good parts at random begins...
