Omega Help Area => Omega Electrical and Audio Help => Topic started by: Mort on 29 October 2011, 17:55:53
Title: Climate Control not working
Post by: Mort on 29 October 2011, 17:55:53
So the climate control was working but all the lights were blown.  I followed the guide on this site to replace the lights, tried to turn it on and nothing happened.  I think I plugged it back in and I have checked the fuses, have I missed anything silly that I need to do to get it to turn on?
Title: Re: Climate Control not working
Post by: RobG on 29 October 2011, 17:57:07
Post by: Mort on 29 October 2011, 19:41:34
Yes, as in I think I checked the obvious things, and wondered if there was something less obvious that I had missed...
Post by: Mort on 31 October 2011, 15:14:31
So I have taken it apart again, it it is defiantly plugged it and still not working.  I assume I have broken it somehow.  Is the unit able to be unscrewed and replaced by another one, and if so does anyone have one for sale (preferably with all the lights working)?
I also seem to have broken my hazard warning switch, so if you have one of those as well I need that too...
Post by: fiend61 on 31 October 2011, 16:14:59
i take it you have tested fuse 14, with a meter i mean  ;) also have you pushed home the plug and secured the catch that holds it in ?  :-\
Post by: Mort on 31 October 2011, 17:49:44
I had a look at the fuse and it looked intact.  I have driven the car and the power steering is still working, I believe that it is on the same fuse.  I have checked and rechecked the plug and it is as pushed in as I can get it, and the catch is pushed in as well.   :'(
Is there a difference between the pre-facelift and mini-facelift hazard warning light switches?  I have discovered that without the hazard light switch in the indicators don't work.  Which is a shame...
