Omega Help Area => Omega General Help => Topic started by: tony2 on 11 November 2011, 23:40:40
hi have started to get the sytems of a faulty battery ie occs slow turning of starter battery only 15months old but only 12month warranty so got batt drop tested appeared ok but still bought new one for £75 with 3yr warranty.after 3/4 days same fault returning occasionly ,alternator charging at 14volt at 2000rpm have taken live and earth leeds of starter and cleaned ok for approx 1 day then system fault starts again no battery leads getting warm is this a sign that starter motor is on the way out ps tried also to take starter motor of but could not get a socket or spanner on top bolt ? do you have to take engine mount off to get at top bolt this is a 02 2.6 cheers tony :'(
have you checked power drain on statermotor turn over? have had batterys tested and come up fine on test but did drain test and it failed.
Engine mount needs to come off to remove starter motor ;). Wonder which retard designed that feature. ::)
try the battery again
new parts can still be faulty
hi everyone (update)
got hold of anther starter motor yesterday was told all v6 the same turns out this one came of a vectra 3.2 same size but slightly of of centre and would not fit :-[ seeing that i allready had starter of decided to have a look and striped down found following, brushes practically none exsited took brushes out of wrong starter reassembled now everything is a1 :y
