Trading Area => Car Parts, bits For Sale & Wanted => Topic started by: duke101 on 19 November 2011, 09:43:12
Title: STOLEN!! HELP NEEDED
Post by: duke101 on 19 November 2011, 09:43:12
I posted recently and discovered my clutch was damaged. I removed the clutch last week and ordered a new one. Went to fit the new clutch only to discover the scrap metal gypsies have pinched both my front downpipes/cats! So i have my new clutch fitted now but no exhaust system...i need the front pipes (ideally) 2 lambda sensors and the brackets that connect each downpipe to the rear of the gearbox. My car is a 2000 V6 Estate Car 2.5l...can anyone help please as the costs are running away with it if i have to buy new.  Paul
Title: Re: STOLEN!! HELP NEEDED
Post by: Bixy1 on 19 November 2011, 09:46:49
That's not nice, sorry to hear that.  :(
Post by: Jimbob on 19 November 2011, 09:47:02
Someone may have some, but expect to pay around £70 each iirc im afraid, they are worth very good money scrap.
Post by: Varche on 19 November 2011, 15:02:05
Two VX ones on this car for only 300 pounds.
http://www.omegaowners.com/forum/index.php?topic=95954.0
Bit of a long drive home but an adventure. Fill it up with cheap booze and cigs at Calais. Break it when you get home....................... ;D ;D ;D
Or get two off a breaker on here :y
Post by: I_want_an_Omega on 19 November 2011, 16:00:43
Hi,
As you can tell, I'm in Lincs also. A pal of mine is about to break a '99 2.5 V6 saloon - but I would imagine that the front down pipes are the same as an estate.
If you interested then PM me and I'll give you his details.
You will need to be quick though as the cats will be cut off and weighted in on tuesday.
He does run a business so you will have to pay for the cats - but I'd imagine that the pipes etc would be included. The car is located in central Lincoln.
Hope this helps - Rob
Post by: 05omegav6 on 20 November 2011, 09:32:09
You shouldn't have to  :-\, but might be worth a call to your local scrap merchant. They may have some in stock... >:( :-X
Post by: Auto Addict on 20 November 2011, 17:48:31
Yes, there's a sign outside a scappy on the Lichfield Rd in Birmingham 'Catalitic Covervters bought for cash'
Post by: Entwood on 20 November 2011, 21:48:33
This may be of assistance ..  Robsey has some for sale ...
http://www.omegaowners.com/forum/index.php?topic=96013.0
Post by: raywilb on 21 November 2011, 12:50:58
i,d check with local scrap merchants & just check. you may just spot them.
