Omega Help Area => Omega General Help => Topic started by: tommyboy1289 on 22 November 2011, 16:29:30
evening guys,
just bought an omega, and accepted a new job 33 miles away to fund it, but already i've got a huge oil leak.
Had a nosy about and all i can say is it's leaking somewhere above the gearbox? anybody got any advice,
Also do we have any mechanics/members in doncaster/sheffield/wetherby area that could fix it if it's not simple?
thanks in advance
Being a four pot i'd say its the cam cover gasket, give it a wash down and have another look. Not a hard job to fix yourself if you which end of a spanner is which.
If this is the problem i'd also suggest fitting a breather box to the crank vent pipe
Cheers
Andy
Possible camcover gasket. Whip the plugs out, if wells are full of oil there`s your oil leak
that leaves alot to go at ;D
have you removed plug leads and checked for oil in wells ? could be camcover gaskets
other than that need some more info on where it is leaking from :y
grrrrrrrrrrrrrrrr must type faster ::)
Havent looked there yet, not very mechanically minded, if i can see where its leaking from then i can pull apart and re-fit but no good at diagnostics.
Will check in the spark plugs tomorrow, would it sound any different? and how much are the camcover gaskets roughly?
thanks guys :y
i am near to donny tomorrow if you want a second opinion and/or a hand :y
What time you around pal? gotta pop to wetherby at some point
tomorrow morning about 10ish if thats any good or could meet you in wetherby
Ill pm you my mobile number pal :y
THANKYOU!
Cheers for popping round today pal, if it's correct I phoned car parts place, he said its a rubber strip type gasket, and mentioned rocker cover but dont think were on par,
What do you think?
Cam-cover / Rocker-cover are the same thing if thats what is confusing you ;-)
And yes it is RUBBER
Use gen vx cam cover seals or you will be doing them again in a couple of months.
Gary.
Is it this one?
http://www.vauxhall-car-parts.co.uk/acatalog/VAUXHALL_CAM_COVER_GASKET_-_90511451N.html (http://www.vauxhall-car-parts.co.uk/acatalog/VAUXHALL_CAM_COVER_GASKET_-_90511451N.html)
How many of the little rubber o-rings will I need?
Cheers guys
Is it this one?
Cheers guys
Nope, that`s a copy. You`ll need 8 "O" rings
Any genuine vauxhall parts dealers online then, wanting to do it saturday/sunday, and is it best to do an oil change at same time?
PM AndyC member on here.
