Omega Help Area => Omega General Help => Topic started by: cuecol on 05 December 2011, 16:25:58
Mystery problem. My headlight/tail light check came on and I found my number plate lamp gone. Replaced it ok, but warning will not go away. I have checked every light, they all ok. Any ideas please. ta.
Number plate light isn't covered by the lamp check. What car is it? Pre face lift saloons have a stop/tail AND a tail light each side, have you checked both? :y :y
And don't use cheapo bulbs. ;) ;)
Thx for the reply. 2.0 CDX SALOON. Every lamp, inc. fogs all on. ??
try some known make bulbs/lamps & see what happens :-\
Ok mate, will give it a whirl. Thx.
If qulaity bulbs fixes it, it's to do with the internal current of cheapo ones vs. decent ones.
Halfords bulbs known to cause this issue - either Vx (expensive) or Ring appear to be OK ;)
resistance :y
I had a similar sounding problem - cured by replacing Halfords stop/tail bulbs with genuine Vauxhall ones. Around 70p each IIRC, not overly expensive!
