Omega Help Area => Omega General Help => Topic started by: Shackeng on 06 December 2011, 19:58:27
Title: TD fuel consumption and performance
Post by: Shackeng on 06 December 2011, 19:58:27
I'm still puzzling over this. The fuel consumption is definitely down by about 15%, and the performance seems somewhat sluggish. Because I rarely push it, I can't really be certain that the turbo is kicking in, it seems to pull away fairly well above 200RPM, but still doesn't feel quite right, and I'm guessing the sluggishness is related to the poor consumption. Has anyone in the Swindon area got a TD so that I can  compare performance? Any further advice would be welcome.
Title: Re: TD fuel consumption and performance
Post by: tidla on 06 December 2011, 20:02:21
drop the rubber turbo pipe off and try it.
Post by: hoofing it on 06 December 2011, 20:38:52
This could be the problem diesels carbon up easy.
give it a good thrashing to clear it's lungs :y :y
Post by: markspark on 06 December 2011, 21:04:09
try putting some diesel magic in the tank it will help clear things out but it could just need a good hard drive diesel cars will soon coke up when only driven at slow steady speeds
go on give it a thrashing it will do you both a world of good  ;D ;D
Post by: Shackeng on 06 December 2011, 22:00:17
Thx guys, I've tried the diesel magic in the filter & tank, tried thrashing it, given it all the usual tlc. I'll try the turbo pipe off tomorrow. :y :y :y
Post by: Kevin Wood on 06 December 2011, 22:05:05
Is there anything on the intake manifold where you can connect a hose to a vacuum gauge? Just thinking you could attach a "lo-gauge" or similar and check the boost pressure is building as it should.
Post by: Shackeng on 06 December 2011, 22:24:25
The pipe at the bottom of the intake which goes to the switch near the PS reservoir might serve, but I know if that's disconnected problems occur. ???
Post by: crossy on 10 December 2011, 13:28:51
Mine was lacking in power and fuel consumption was down too and i changed the map sensor and it was perfect. The little pipe on the map sensor breaks away so easy and you can not see it and this makes it seriously lack in power.
Check it out at this link http:
//www.omegaowners.com/forum/YaBB.pl?num=1305496087/4#
Post by: Shackeng on 10 December 2011, 16:47:11
Thanks Crossy, I've already checked the pipe is fitted to the MAP OK, but maybe the unit has failed. I'll try a replacement.  Cheers. :y
