Chat Area => General Car Chat => Topic started by: smithpa7 on 19 December 2011, 15:33:55
Title: KwikFit
Post by: smithpa7 on 19 December 2011, 15:33:55
I have used my local Kwitfit for over 20 years. They have been extremely helpful in all of that time, I know many others have had bad experiences.
However, the BMW wouldn't start the other day due to a flat battery. So I got it started and went to Kwikfit, the battery is only 11 months old and has a 3 year warranty from Kwikfit.
The new manager, Paul, introduced himself and invited me to watch him testing the battery and alternator, so far so good!
His tester showed the output voltage from the alternator under a full electrical load was 13.0v. I know this slightly low, so I asked him if maybe the fan belt was loose or if the car had a bad electrical connection? In a flash he stated it couldn't possibly be either of those and I will need a new alternator. He had a price for one in seconds (£317 fitted) and said he could fit it on Monday.
I politely declined and said I would come back to him.
I did follow Kevin Wood's excellent guide and everything is within tolerance except my digital meter was showing 13.5v under full electrical load.
1. Was I wrong in assuming it could be a fan belt or electrical connection problem?
2. Is 13.0 v too low under full electrical load? (13.5v with my own digital meter)
3. Is £317 a good price for an alternator?
I have since fully charged the battery through a battery charger and it is working fine and the battery is holding charge overnight at 12.6v.
Do I need to do anything? All help would be most appreciated.
Title: Re: KwikFit
Post by: JamesV6CDX on 19 December 2011, 15:40:25
Have you done lots of short journeys with loads of electrical stuff running? :)
Title: Re: KwikFit
Post by: smithpa7 on 19 December 2011, 15:52:51
For a few weeks to be honest, SWMBO does a couple of journey's a day that are less than two miles and headlight, fans etc are all running.
Title: Re: KwikFit
Post by: Ken T on 19 December 2011, 15:53:54
You might want to check the battery terminals are crimped tightly, see http://www.omegaowners.com/forum/index.php?topic=90122.msg1152291#msg1152291
Ken
Title: Re: KwikFit
Post by: smithpa7 on 19 December 2011, 16:00:24
Thanks Ken, I will check the terminals.
One other question, the battery in the BMW Touring is in the boot the terminals have never had any grease on them. The last battery was the original. Would it help if I applied some grease??
Title: Re: KwikFit
Post by: Ken T on 19 December 2011, 16:02:08
1.no, if the earth or terminals were not secured properly or oxidised, there will be a volts drop across them.
2.yes
3.yes (for kwik fit)  :P
12.6V is a bit low for a fully charged battery.
Ken
Title: Re: KwikFit
Post by: Ken T on 19 December 2011, 16:10:10
Ah that's slightly different, if the battery is in the boot it is possible to have an appreciable volts drop along the long cable, the Omega battery is within a couple of feet of where it has to go to.
I would still go by KW's guide and expect the alternator output into a fully charged battery, say after a long run to be up in the 13.5V region at least. Check where the battery earth goes to, if it bolts straight to the body, make sure its a good clean contact. I've never used grease on terminals, if the battery and terminal surfaces are fairly clean ( sandpaper ) before bolting together they tend to stay OK.
Ken
Title: Re: KwikFit
Post by: Kevin Wood on 19 December 2011, 16:16:42
First thing to check is for dodgy connections and decent drive to the alternator. Quite how it "couldn't possibly" be that, I don't know. The alternator is the source, and there's a bit of wire connecting it to the battery, where you're measuring. >:(
Yes, 13.5v is a bit low, and it's worrying that KF's meter read even lower (perhaps they have "specially calibrated" ones).. If it picks up to 14 - 14.5V or so without load I wouldn't worry too much, but I suspect the fact that it went flat is indicative of a problem somewhere.
They have failed to diagnose the problem and picked the "fix" that would give them the greatest profit, knowing that if they happen to find a loose connection or corroded terminal while changing the alternator, they'll fix it and you'll be none the wiser.
£317 to change an alternator sounds steep to me.
Title: Re: KwikFit
Post by: Kevin Wood on 19 December 2011, 16:17:16
Just to add, it might be worth measuring the volts at the alternator output. :y
Title: Re: KwikFit
Post by: smithpa7 on 19 December 2011, 16:37:50
Thanks Ken and Kevin, I have checked all the connections I can in the load bay, they all appear to be tight. I have tightened them a little bit.
The battery is in a fully charged state, so I ran the full load test again, my digital meter was showing 13.9v, i think this is a good sign  :y
I believe Kwikfit have recently been taken over, maybe the new regime intend to 'screw' the customer??
I now suspect that the battery has slowly ran down over the last couple of weeks. SWMBO does leave everything running even when it is not required ::) ::)
I think I will use the car as normal and carry the jump leads just in case. I suspect it may no longer be a problem.
Thanks Guys :y :y :y
Title: Re: KwikFit
Post by: Marks DTM Calib on 19 December 2011, 16:40:36
As for the slipping belt question, yes you were wrong as you would hear it due to the very obvious squealing noise  :y
On the remote battery setups I would expect a lower voltage on full load but, the price quoted is not great by any means. The fundamental test is, is the battery voltage higher with the engine running than with it stopped, if yes than the alternator is doing 'something'.
Remember also that a modern car with full load can consume 100A which is pretty much the full alternator output so the charge voltage will drop.
Title: Re: KwikFit
Post by: Marks DTM Calib on 19 December 2011, 16:41:30
No, thats been the approach for the last 15+ years  ;D :y
Title: Re: KwikFit
Post by: TheBoy on 19 December 2011, 17:29:19
I reckon its all the short journeys, esp this time of year, not allowing the battery time to recharge after starting...
Title: Re: KwikFit
Post by: I_want_an_Omega on 19 December 2011, 17:43:28
I agree. Some years ago I "overloaded" the boot of my Cav GSi by shoving too much stuff in. Turned out I damaged the switch for the boot light meaning it was on all the time. Was fine overnight but would always need to be jump started on a sunday if not used on saturday! So, probably just taking it for a 10  mile run once a week would probably be enough to keep all in check rather than the very short stop/start trips. SWMBO used to do a 4 mile trip to work for many years and never used her car at the weekend - all was fine, so its that extra few miles that can help recharge the battery.
Title: Re: KwikFit
Post by: feeutfo on 19 December 2011, 18:24:38
Vx do an exchange sevice on alternators, or they did a few years ago. They give a large chunk of cash back when you return the old one... IF thats your problem.
If its the battery, Gm items are very reasonable on tc, also have a 3 year warranty, and i'll bet they are conciderably more reliable than the crap kwick fit and Halfords sell.
If only ever used Kwickfitup, how do you know they are competitive...? ...or not?
Sorry but they prey on the unwarey imo!
Title: Re: KwikFit
Post by: Andy B on 19 December 2011, 19:01:33
Not that bad. I was speaking to a bloke the summer before last on a caravan site. His diseasal Vectra's alternator had died, so was taken to the nearest vauxhall dealer by his recovery firm, where they charged him £560!  :o :o :o
Title: Re: KwikFit
Post by: tango on 19 December 2011, 19:41:04
how old is your BM
a freind of mine recently had a charging issue with his bmw 525d e60
he went to kwik fit who told him that his alternator had packed up and due to that the battery also had died
anyways they replaced the alternaator and battery and off he went
2 days later and the same problem
so he went back to kwik fit who said the alternator had packed up and maybe it was a dodgy one so they repced it free of charge
as he drove out 2 mlies down the road and battery light on again
kwik fit then recomended that he leave the car and further diagnoses would be done
after inspection by there so called specialst, kwik fit said some charging sender unit relay type thing had failed and needed changing so another £190.
and after that guess what, yep same thing,
by this time he had enough and though might uswell go to bmw,
now, bmw told him that these cars are installed with some smart charging circuitry and the car needs to be told when a new battery is fitted,
obviously kwik fit didnt know this
however bmw done thier thing wacked him with a bill of £300+ for some relays that had gone due to kwik fit erroe and all is now well.
his case with kwik fit continues
Title: Re: KwikFit
Post by: D on 19 December 2011, 21:07:32
I think he is talking about his BMW. BMW prices are about three times that of a Vx dealer.
Title: Re: KwikFit
Post by: TheBoy on 19 December 2011, 21:19:01
I've found BMW parts prices to be relatively reasonable. But their service departments are every bit as useless, incompitent and retarded as Vx dealers.  But BMW owners are far too stupid to notice ;)
Title: Re: KwikFit
Post by: feeutfo on 20 December 2011, 00:36:16
quite right D. That'll teach me, mobile at work, board between jobs. You know how it is.
Although, might fit...? Maybe?
Title: Re: KwikFit
Post by: smithpa7 on 20 December 2011, 07:06:08
I couldn't agree more  ;D ;D
