Omega Help Area => Omega Electrical and Audio Help => Topic started by: Father_of_four on 20 December 2011, 18:58:14
Hi Any advice please ?
A few weeks ago went out to my Omega 2.6 Elite Estate to find passenger side indicator lights on but very faint.Tried to start no go battery flat as the preferble. Once the happy chap from Thames valley motors boosted my battery off i went to work. Since that day only the passenger side lights flash when press the keyfob and had no use of the radio.
first question is the problem with the lights not flashing a fuse or relay ??
Secound question why does the radio code on the front of the what i think is the original handbook not work ?? I am on the last four attmpts at entering the code. I have had a good look through some of the recommendations on the site and not had any joy in getting my music back. yhis has been a very frustrating problem as I twice weekly have a 1/2 hr trip to and from North Wales. Any experts happy to help me with these niggleing problems to help me enjoy driving waht I think is a cracking cruiser.
regards
Not leather (Craig)
Radio needs code as battery went flat. Thats a nice simple problem... ...IF you have the right code
Indicator... ...try repeatedly pressing the hazard switch about 30 times, see if that helps :)
Can certainly help you with the code number, but would need to know what radio you have so that I can point you in the right direction
Thanks
Will get the radio model and try the pressing the hazard light button. That was meant to read 3 1/2 hr drive to North Wales.
I may have misunderstood the Q slightly, sorry.
Do indicators work normally (assuming you're not a BMW driver ;D)
Yes the indicators are working fine, the problem is when I press the keyfob to lock the car, only the pasenger side flashes ??
Possible dodgy relay that controls "alarm set" indicators. Lives at top of passenger kickpanel, grey in colour
Thanks
Robg will check this out asap
If you can`t access the relay you will have to remove glovebox
I won't be attemting that tonight then !!
Thanks again
just off to check the radio model for dave
Thanks again
I`d guess CCR2006 if no satnav
Correct ROBG it is the CCR 2006
Either locate an audio decode specialist locally (£25-35) or contact Dave on here.
http://www.omegaowners.com/forum/index.php?action=profile;u=2139
http://www.dndservices.co.uk/product.php?productid=5921&cat=0&page=1
If it wasn't such a pig of a job I would suggest pulling the radio and checking that the code wasn't written on the back. ;)
Never had any problems, reckon it`s a doddle getting the double dins out ;)
should have come to you then rob ;) all of mine have been right pigs :-X
unless of course you are taking everything apart and pushing from behind ;D
I take it you're entering the code in the right manner, ie not by using the numbered buttons at face value?
Just a thought, easy mistake to make tho I appreciate you have researched the site .......
Agreed, no problems getting it out, and back in..... :) With facelift, got a bugger of a problem with pre facelift radio/cassette often stops working, take out and a fiddle put back in and it works, done this several times, this time can I get it back in fully, no way, sticks out about a quater of an inch, tried and tried but can not push it back in fully, working though.... ::) ::) ::)
