Omega Help Area => Omega General Help => Topic started by: moose on 02 January 2012, 17:27:00
Title: Fault Codes please
Post by: moose on 02 January 2012, 17:27:00
Hi all.
Got the warning light coming on sometimes when starting (car with spanner) and the engine cuts out,pedal trick shows 1613 and 1612.Any ideas please 2001 2.6 MV6 ::)
Thanks guys if its a sensor can you please also tell me where it is !!!
Title: Re: Fault Codes please
Post by: hotel21 on 02 January 2012, 17:35:26
http://www.omegaowners.com/forum/index.php?topic=90633.0
Post by: Welung666 on 02 January 2012, 17:44:44
Those are both immobiliser codes. You need to check the transporter in the key is secure and the immobiliser ecu is properly plugged in around the ignition barrel.
Post by: moose on 02 January 2012, 18:02:47
Thanks guys i`ve been having trouble with the connections in the key ,,got a piece of card in there to keep it tight , maybe this was the problem.
I will use the spare key for now and see if it happens again.
thanks again all,
Marcus.
