Omega Help Area => Omega General Help => Topic started by: Shackeng on 02 January 2012, 18:46:56
Title: 3.2V6 breathers
Post by: Shackeng on 02 January 2012, 18:46:56
Having read the guide, at what frequency is it recommended to clean these?
Title: Re: 3.2V6 breathers
Post by: Welung666 on 02 January 2012, 18:52:10
I'd recommend doing them annually.
Post by: Shackeng on 02 January 2012, 18:53:42
Cheers Lee, I am only doing about 3000m a year in the 3.2, does that still apply?
Post by: Welung666 on 02 January 2012, 18:56:03
Even more so in your case, lower mileage will greatly increase condensates to form in the breathes.
Post by: Shackeng on 02 January 2012, 18:58:00
B*&%@r, yet another job to do this winter :y :y :y
Post by: Kevin Wood on 02 January 2012, 19:25:47
Once they have been properly cleaned out once, I just check them every oil change. Remove the pipes at the rear of the plenum cover and, by blowing down a length of hose, check each breather is clear both up towards the plenum and down to the breather box. A squirt of carb cleaner into each for good measure and leave it at that, if all appears well.
Post by: robson on 02 January 2012, 19:30:55
If you take Kevins advice do you have to do an oil change having injected carb cleaner and does a long run now and again help to clear the breathers
Post by: Kevin Wood on 02 January 2012, 19:35:41
A little squirt of carb cleaner (i.e. not a whole can) will do no harm. I just do it with an oil change by routine.
A long run will indeed help, as it removes all moisture from the crankcase if the oil is hot for an extended period of time.
Post by: Shackeng on 02 January 2012, 23:10:55
Thanks KW. :y
Post by: TheBoy on 03 January 2012, 11:17:09
Indeed, I do mine annually (in the summer!) along with TB clean etc.
For shorter journeys, I'd probably consider 3 times a year, esp if the oil you use has a habit of mayoing on shorter runs (check oil cap)
Post by: Shackeng on 03 January 2012, 11:23:08
 :y :y :y
