Omega Help Area => Omega Electrical and Audio Help => Topic started by: nilocp on 04 January 2012, 20:56:35
Title: Interior Light
Post by: nilocp on 04 January 2012, 20:56:35
Hi guys, my interior light works when the door is opened.
But does not work on either of the switches by the light!
Any ideas where to start looking please??
Colin
Title: Re: Interior Light
Post by: Welung666 on 04 January 2012, 21:09:20
Hi Colin, the switches are for the map reading lights and only work with the ignition on. Try pulling the headlight switch out if you want an interior light on without the ignition on :y
Post by: Andy B on 04 January 2012, 21:13:42
Colin
Please read the manual  ;) ;) ;) ;) :y
Post by: Andy B on 04 January 2012, 21:15:35
Also depends which courtesy light. Pulling the headlight switch will turn the courtesy light on while driving if you wanted, but as you say, each switch either side will turn its map light on.  :y
Post by: nilocp on 04 January 2012, 21:30:48
Right! You live and learn. Pulled headlamp switch out, and yes got interior light! :y
It is the map lights that are not working.
So why would that be?
CP
Post by: hotel21 on 04 January 2012, 21:35:31
Lamps blown?
Post by: Welung666 on 04 January 2012, 21:35:54
First off check the bulbs ;)
Post by: Andy B on 04 January 2012, 21:36:57
CP
Ignition on?
Post by: Nick W on 05 January 2012, 10:09:47
Mine didn't have any bulbs in the map lights. Which is why they didn't work!
Fitted some(they're the same as the existing courtesy lights), and they work fine.
Post by: nilocp on 05 January 2012, 23:38:17
Thanks guys all sorted now!!! :y :y :y
CP
Post by: jonny2112 on 06 January 2012, 00:05:23
Was it the bulbs then? Or lack of them?
Post by: nilocp on 08 January 2012, 19:58:02
No, they work fine when the damn ignition is on!! :-\ :-\ :-\ :-\
Post by: Andy B on 08 January 2012, 21:33:57
