		Omega Help Area => Omega Electrical and Audio Help => Topic started by: Tangerine on 05 January 2012, 19:59:13
				The info display on my Diesel Omega CDX Facelift has gone completely blank.  According to the fuse diagram it shares fuses with other electrical items but these are all working fine.
 Any ideas would be appreciated.
				Presumably MID?
 Not turned dash backlighting all the way down (dial on headlight switch)?
 4 blown bulbs in MID unit (was it getting dim in some corners?)
				Thanks but No, neither of those.
 Display had been working perfectly and then nothing!
				are you sure it was perfect?
 Ive seen many just running on 1 of the 4 lamps, yet the owners have always been unaware until its pointed out.
 new lamps would be my 1st call...
				What fuses did you check?
				I guess it will not be easy to get at the lamps?
				I will check which fuses in the morning.
				lamps not that hard actually, 5-10 mins, check removing the clocks guide in the maint section, link to the index in my sig.
				Have you tried pushing in the stereo from the top left and right
				Jobs a goodun!
 Thanks to all who replied in particular RobG.
 As a result of your reply I actually removed the fuses.
 I had previously just checked that the features controlled by the same fuse were working.  However, after removing and checking the fuse, which was fine; I turned on the ignition and the display was working again.  I don't know why which is the worrying part but I removed and replaced the fuse a few times and everything is still OK now.  This was fuse number 26.
 Thanks again.
