Omega Help Area => Omega Electrical and Audio Help => Topic started by: Gaffers on 09 January 2012, 09:00:15
Title: HID Problem
Post by: Gaffers on 09 January 2012, 09:00:15
After changing the bulbs on my HIDs they were working ok.  Yesterday after switching them on one (the one that was pink before) did not light up, I switched them off and on again and it was fine.
This morning it wont work at all.  When I switch the HIDs on it lights up for a second and then goes out.
Is this the ballast or is the bulb fubar?
Title: Re: HID Problem
Post by: Kevin Wood on 09 January 2012, 09:31:35
Could be either, but if the bulb has recently been changed I would suspect that. Maybe you got a duff one.
Can you swap the bulbs and see if the fault follows the bulb?
Post by: Gaffers on 09 January 2012, 09:35:37
I could but it's bugger to get in and out as I have to remove the battery.
I wonder if it's the connector?  User error maybe?
Post by: dbug on 09 January 2012, 15:52:46
Possible - as said mate try swapping bulbs and see if problem moves or magically fixes itself ;)
Post by: Marks DTM Calib on 09 January 2012, 15:59:22
If not I have a spare ballast
Post by: tango on 09 January 2012, 16:35:29
if it was pink then could be the bulb but as mentioned above try swapping the bulbs
youll find it easer to remove the whole headlight
Post by: Kevin Wood on 09 January 2012, 17:10:02
If it is lighting up initially the ballast is obviously providing a high enough voltage for it to strike. I wonder if it's then shutting down due to an overload or something?
I think you still need to swap bulbs to diagnose, unfortunately. :-\
Post by: TheBoy on 09 January 2012, 18:55:41
Weren't cheap nasty bulbs you bought, were they?
Post by: Gaffers on 09 January 2012, 19:55:46
They were off ebay but I expected them to last longer than 2 days  :o
Post by: TheBoy on 09 January 2012, 19:57:20
The shite ones are, errr, shit.
Post by: Jimbob on 09 January 2012, 22:01:26
Too many bad stories with cheapies, including fire.
Osram or Philips only imho  (I was lucky with chinese ones, but that was a long time ago, and they were not as good as branded, all though they worked.)
Post by: joff on 09 January 2012, 22:18:54
Did you not put an higher than normal rated set in :-\ i think i have seen that on here before, must have been over a year ago but can't remember the outcome (oldage you know) i have a set of of HID'S off the 02 Elite here if the bulb's are the same on the MFL as they are on the FL with ballast packs working if you need them :y
Post by: dbug on 09 January 2012, 22:20:04
Got some cheapies off ebay a while back - Hungarian made Osram - been ok.
Post by: Tonka. on 09 January 2012, 22:43:08
Made exactly the same mistake myself. Mine didn't even do 2 days. It was instant failure. Both struck and then nothing.
I bit the bullet and bought a pair of these - - - > http://www.hids4u.co.uk/osram-d2s-xenon-hid-headlight-bulb.html  ;)  (http://www.hids4u.co.uk/osram-d2s-xenon-hid-headlight-bulb.html)
Post by: Topuz on 09 January 2012, 22:48:50
I have the same problem with my bulbs. Most of the time they light up the first time, but occasionally one or both fail to light up. When I turn the switch off and then back on, they're ok. Truth to be told, my HIDs are aftermarket ones and were installed before I got the car and it was obviously a half-ass job.
I'm currently trying to solve this problem and I initially thought that the ballasts have to be the problem, but after seeing this thread I guess I could change the bulbs first.
I'm not familiar with UK laws, but here in Serbia we must drive with dipped beam during the day as well and I'm afraid I'll get the ticket because I sometimes don't notice they didn't light up (and I can't be bothered to get out of the car every time to check).  :P
