Chat Area => General Discussion Area => Topic started by: geoffr70 on 19 January 2012, 15:02:25
Title: Mobile phone charging mats
Post by: geoffr70 on 19 January 2012, 15:02:25
Hi peeps,
does anyone have any experience of these mats that you place your phone and other small electrical devices on to charge, without actually plugging the charger into the socket of the phone?
My iphone 3gs has got that dreaded unable to charge problem, which is crap as I was going on to giff gaff with it and stopping my soon to be finished contract and saving money. But if the phone is kaput i can't as i couldn't be without an iphone now and i don't want a new contract or the expense, so thought I could use one of the charger mats to get around this problem.
I've already dismantled my phone and have a new charger module thing on the way, so hopefully that will work, although I think the problem is software related.
Thanks peeps
Title: Re: Mobile phone charging mats
Post by: Martian on 19 January 2012, 16:31:37
Save your money towards a new handset.
Post by: geoffr70 on 20 January 2012, 13:25:44
Ok they're crap then, thanks!
Post by: Martian on 20 January 2012, 14:28:26
It wouldn't solve your problem anyway Geoff because you still need to plug the wireless receiver in to your phone in order to charge it.
Post by: geoffr70 on 20 January 2012, 15:10:33
I thought it did it by magnetic magic or some other sort of trickery? Anyway I've just fixed it by replacing the charging module, yippee!
Post by: SteveMJ_new on 20 January 2012, 17:46:47
The charging mat technology (as best I understand it) is effectivly a split of the two halves of an electrical transformer.
The primary is in the charging mat and the secondary in the product to be charged (or multiples secondaries for multiple products).  I am sure there is or will be features to stop energy passing into and being absorbed by non-target products. i.e. you would not want to leave any metal item on the mat and for it to get hot.
Steve
Eur Ing Stephen Morris-Jones  BSc(Hons) CEng MIEE
Post by: Mr Skrunts on 21 January 2012, 05:44:32
Other option is buy a spare battery or 2, get a battery caddy charger and swap batteys every day.
Is your charger acrually working?
I just got a Galaxy IIS, first thing I got after that was a docking stand, drop the fone into it, it charges and sycs data to PC (once I can get a program to work with it) but can move MP3 and pics about with no probs.  Plus I also got the spare battery and battery charger/caddy.  Plus geared up with car charger etc.  (Amazing how much they go flat downloading appz while Mrs Skrunts is in the supermarket.    ::)
Post by: geoffr70 on 21 January 2012, 07:44:16
Chargers working, charge module isn't. I wouldn't fancy replacing an iPhone battery every day. Replacing the charge module (which incorporates the antenna, mic and loudspeaker etc) fixed it.
Post by: Martian on 21 January 2012, 10:05:00
Swapping an iPhone battery isn't as simple a task as you think Skrunts, the handset has to be taken apart (literally) in order to replace the battery on an iPhone
Be careful if the spare battery/charger is a cheap chinese clone (eg, Anker) Skrunts, quite a few S2 owners have had them explode/catch fire when in use.
Going back to your other problem regarding not being able to sync with Kies correctly, were you using the dock when you were trying that?
If the answer is yes then you need to take the dock out of the equation and connect the handset directly to the PC via the supplied USB cable.
I would also recommend you ditch Kies in favour of a piece of software called MyPhoneExplorer.
It's completely bloat free (circa 4MB), urinates all over Kies for what you can actually do with it, and unlike Kies it won't install other 3rd party software behind your back that you cannot remove afterwards.
The MyPhoneExplorer client for the handset can be downloaded from the Android Market >HERE< (https://market.android.com/details?id=com.fjsoft.myphoneexplorer.client&feature=search_result#?t=W251bGwsMSwxLDEsImNvbS5manNvZnQubXlwaG9uZWV4cGxvcmVyLmNsaWVudCJd)
The MyPhoneExplorer main application which goes on the PC can be downloaded from >HERE< (http://www.fjsoft.at/en/)
My antivirus proggy (NOD32 by Eset) throws a little wobble when I select the downloads page for the main application, but I can assure you that it is nothing more than a false positive if yours does the same. Pay attention when installing the main app as it will install a 3rd party toolbar (Babylon) by default unless you tell it not to.
Lastly, you will need to enable "USB Debugging" on the handset itself as the Sammy MTP application (which is crap anyway) will cause issues when trying to connect.
To do this, go to Menu > Settings > Applications > Development and place a tick in the relevant box
After enabling USB Debugging, you will have to manually tell the handset to connect to the PC under some circumstances in order to stop the MTP application from interfering with things. To do that, drag the status bar on the handset down and you will see an option in the notification area that says "Select to copy files to/from your computer".
Once this is selected, you will be presented with a picture of Andy (the droid) in green with a button underneath that says "Connect USB Storage". When a successful connection is made, Andy will change colour from green to orange to indicate connectivity.
To safely disconnect once you are done, simply press the button underneath the orange Andy that says "Disconnect storage from PC"
Hope the above helps, and if you want to know anything else about the SII then feel free to ask.
