Omega Help Area => Omega General Help => Topic started by: thebaldeagle on 23 January 2012, 19:21:07
Daft questions possibly...
Ive owned quite a few Vauxhalls and when ever the front or rear fog lamps have been switched on there is always some sort of illumination on the dash to show that you have 1 or the other on... :)
BUT...was out in the miggy before and didn't realise the front fogs were on because there is no illumination on the dash? :-[...is it just our car or should we have some sort of symbol on the dash to tell us otherwise?
Later models had dash illumination, early ones had switch illumination
Should of said its an MV6 2001..i would of thought it should of had dash illumination
sounds like we have bulbs out on the dash then?...
Yep
http://www.omegaowners.com/forum/index.php?topic=90618.0
http://www.omegaowners.com/forum/index.php?topic=90644.0
Yep
You will have an illumination on the dash -- got some nice LED bulbs in my fogs gay is what you said was it not Rob lol :y
Yep
Yep ;D
just checked thro the user manual and can't see anything in there that says illumination occurs on the dash?...anyone got a pic of their dash with the fog lights switches/lights illuminated?
thanx for all your replies,not a major prob i know,but frustating all the same lol
Page 28 http://images.omegaowners.com/documents/UserGuides/OmegaOct2002.pdf
You`ll see the icons bottom left & right in speedo dial
Cheers Rob...looks like dash out and gets some bulbs replaced soon ::)
One of the easier jobs on a Mig ;D
Lights up green for the front.
and red for the back ;D ;D
Are they a certain type bulb then guys?
Just to check, OP, you're not a foglights-when-its-not-foggy muppet are you?
These will do, either 1.2W or 2.0W
http://www.autobulbsdirect.co.uk/R509TMGR-Dashboard-Bulbs-12V-2.0W-Light-Green.html
Suggest you buy a couple of those . . .
I recently fitted a set of front fogs to my 2.0 GLS, and finished the job off with the indicator bulb in the dash.
The front fog indicator light is at about 7 o'clock in the speedo dial when you're driving. I managed to wreck the first bulb I put in by turning the thing the wrong way. It's very obvious which way it goes in if you have a quick squint inside the hole before stuffing the bulb in. :D
N
cheers for all the assistance guys!! :y
Was just reading this and realised that on my omega when I turn on lights only displays light up, there is no indicator light to say that they are on but other indicator lights come on for fogs and main. Is this normal.
what year is mig.
what year is mig.
99 PFL
what year is mig.
99 PFL
There's no tell tale on the dash to say you have lights on if that's what you mean. Confirmation is if you can seen where you're going when it's dark. ;) ;) ;) ;)
what year is mig.
99 PFL
:) just about see where I'm going haven't got my level sensor fixed yet ;D thanks anyway just every other car ive owned had a tell tale light
