Chat Area => General Car Chat => Topic started by: TheBoy on 30 January 2012, 17:30:02
Title: MOT fail, but on what?
Post by: TheBoy on 30 January 2012, 17:30:02
The Silver Bullet failed its MOT today  :'(, not unexpectedly  :-[
The headlight aim was out, adjuster not doing anything useful. *sigh*
But did it fail on anything else?
Title: Re: MOT fail, but on what?
Post by: aaronjb on 30 January 2012, 17:30:50
I foresee predictable voting, here..
Post by: Lazydocker on 30 January 2012, 17:32:35
Disappointed I can only choose one item, I'd have loved to vote for the dangly thing just for giggles ::)
Voted seriously for once, handbrake efficiency ;)
Might be time to try replacing the cable :-\
Post by: joshwyatt on 30 January 2012, 18:14:36
I'd agree with LD on the handbrake, it was by all accounts, bleedin' naff when I drove it  ;D
Post by: henryd on 30 January 2012, 18:17:20
+1 as its been a topic here in the last few days ::)
Post by: TheBoy on 30 January 2012, 18:30:04
Those buggers voting for air freshener are lucky this software hides who voted what  >:(
Post by: henryd on 30 January 2012, 18:33:43
And there was me thinking you were baiting them prior to banning :D :D ;D
Post by: venom on 30 January 2012, 18:45:06
I'm going to go with handbrake but for some reason I think It's something more trivial than that like indicators too white :o
Post by: hercules on 30 January 2012, 19:09:06
you really ought to try feu de orange
Post by: LJay on 30 January 2012, 19:09:58
I wanted to pick everything on the list....sulk!  Your car's knackered, but loveable.  Just like you TB! :-*
Post by: Andy B on 30 January 2012, 19:19:18
 ;) In that case ...................  ::) ::) ::) ::) ::)  ;D ;D ;D
Post by: Gaffers on 30 January 2012, 19:23:16
I see a hook, and on it is a lovely juicy yummy worm..... :-X
Post by: Andy B on 30 January 2012, 19:25:17
I'm not that daft that I'd vote for something straight away ............  ::) ::) ::) ;D ;D ;D Unless of course someone votes to stitch me up!  ??? ;D
Post by: Reefpotato on 30 January 2012, 19:42:51
Actually I think anything blocking the drivers vision is illegal and a fail, so if they wanted to be awkward and not remove it themselves it could fail? Fluffy dice spring to mind, or how big is the air freshener and wheres it hanging lol
Post by: PhilRich on 30 January 2012, 19:53:27
The amount of rubber you admit to leaving all over the gaff it has to be tyres below the legal minimum! ;D ;)
Post by: feeutfo on 30 January 2012, 20:00:11
Voted rear tyres low, but suspect corrosion issue.... Surely by now?  ;D
Post by: Andy B on 30 January 2012, 20:03:14
Actually I think anything blocking the drivers vision is illegal and a fail,  ......
In that case, if I was a Traffic Copper I'd remove all the TomTom/sat-nav/etc that you see in the middle of the screen directly in front of the driver (......... how the hell can you see where you're going with it there) and make the driver drive over the thing!!!  >:( >:( ::)
Post by: tidla on 30 January 2012, 20:06:49
not so long ago in new trucks we had to reposition the rear camera monitors on the dash they were failing the mot. even stickers across the top of the screen which crossed into the swept zone by more than 40mm.
Post by: hoofing it on 30 January 2012, 20:09:15
Am to feert tae vote it   '    it's there  :-X :-X
Post by: hoofing it on 30 January 2012, 20:10:50
liar liar pants are on fire :P :P
Post by: TheBoy on 30 January 2012, 22:08:48
Being a new member, you will be unaware that I cherish the VT30 I have, stating "Air Freshener".
Cherish? That wasn't quite what I meant...
Post by: sticka_v8_init on 30 January 2012, 22:54:11
As stated, the handbrake seemed the obvious so gone for "other lights" with a guess that the lenses are milky!
Post by: feeutfo on 30 January 2012, 23:12:04
..well you do show said fail cert to visitors quite regularly. (snigger)
Post by: Auto Addict on 31 January 2012, 08:05:30
Is the clue one of them is in bold?
Post by: Del Boy on 31 January 2012, 08:54:15
Ive voted  ::)
Post by: henryd on 31 January 2012, 09:44:13
I think that's just the one with most votes.
Post by: Auto Addict on 31 January 2012, 11:02:23
Have another look ;)
Post by: TheBoy on 31 January 2012, 20:39:18
break orrrfffff  >:(
Post by: TheBoy on 31 January 2012, 20:39:50
Vote closed.
Post by: b4ndit on 31 January 2012, 20:52:47
i voted discs and pads ;)
Post by: sticka_v8_init on 31 January 2012, 21:44:58
Vote closed.
Come on then........what's the answer  :)
Post by: feeutfo on 31 January 2012, 21:54:44
break orrrfffff  >:(
;D  :P
...so do us two get a prize?    :D
Post by: TheBoy on 31 January 2012, 21:58:06
The answer was the very top one......
Post by: feeutfo on 31 January 2012, 22:00:34
What? You broke your Poopoooop...? ;)
Steering wheel related? :-\
Post by: TheBoy on 31 January 2012, 22:08:49
Not being Toad of Toad Hall, I never use it (probably last used at last MOT ::)), so did immediately think steering wheel.  I'm more of a flasher, oooo-errr!
Don't think its wheel related - can hear the relay clicking when switch pressed.
Tried a replacement horn, and a replacement relay, still no workio.  Need to go through it methodically now.
Post by: Andy B on 31 January 2012, 22:28:19
Don't/shouldn't you have two horns? a 500Hz & a 400Hz to give a 'twin tone' horn. One of my horns stopped working, swapping over horns/wiring suggested it was a feed problem. The cause was that the wiring had been chaffed right through on one side by the convoluted conduit under the battery tray somewhere.  :)
Post by: TheBoy on 31 January 2012, 22:33:04
Yup, dual horns, but only have 1 spare in garage.  So unless my 2 on the car, plus the one in the garage has failed, I too will be chasing the wiring, so your post has been very helpful :y.  Bumper is off anyway, for the headlight removal, so hopefully should be easy to see if its in that area.
Post by: smithpa7 on 31 January 2012, 23:12:39
At last, I have guessed right ;D ;D ;D
Post by: TheBoy on 01 February 2012, 13:22:29
Headlights refitted at 7:15 this morning, just as it got light.  Brrrrrrrrrr.
Fault found with horn, bodged to prove, proper fix tonight (might struggle with one bit, might have to run off one horn until I can get a part), bumper back on, tweak the headlight aim to be close-ish.
Booked back in Fri morning.
