Chat Area => General Discussion Area => Topic started by: alfie on 03 February 2012, 17:29:22
HI All, help needed here,got a sky hd box today,got that up and working but the remote will not operate the tv side of things.
the code for my sony bravia tv should be 0000 but the remote ill not accept it,phone sky tech dept,all of their solutions were useless.
All replys welcome,pulling my hair out now,if it don't work they can have it back.
ps a lot better picture on this box than the sky + one.
Alfie.
go to interact
sky active
help and support
program your remote
follow instrutions
remember to cover remote to stop signal getting to skybox
hope this helps
Acccording to my book it should be a 3 digit code......and one of these...
006
301
005
446
412
393
375
360
325
255
203
185
174
058
003
HTH :y
There are very often more than several codes that work for any given tv.
Google your issue and codes for your model tv. It's all there. And I doubt 0000 will work with any tv tbh.
Should be able to code it to operate a home cinema for volume as well.
Alfie.
Thats not the right code :y
Thanks to all who advised me,all sorted now the code was 0533. I must say that this HD box is a vast improvement on the sky + one.
Thanks, Alfie.
Thanks, Alfie.
Is it a 1TB one?
I had a standard HD box, then got a 1Tb as part of staff trial. Was watching BBC1 HD, swapped it out, put new one in, again quite an improvement in picture. Looked a lot "crisper"
Thanks, Alfie.
Is it a 1TB one?
Seems odd to see a better picture...?
Hd on both surely?
Thanks, Alfie.
Is it a 1TB one?
Hd on both surely?
Was odd, but direct swap out, just minutes between seeing same picture again. FatherT commented as well, its a newer box design, in house this time, rather than contract built.
Better decoder maybe? I used same cables, just box swapped.
Now thats sorted,another issue has cropped up,I need to activate the 2nd RFout,do anyone know which settings I need to get into.
Alfie
Forgot to tell you,no manual with self installation boxes.
Google service menus. It's in there. 01 select. Or sumat.
Hi all,sorted the rf2 problem,why do they have to make everything so bloodly difficult for knobs like me.
Anyhow with that said,another problem has raised it's ugly head.My broadband speed has dropped to around 3meg from 7.5meg,spend around 30 mins yesterday talking to some guy in india,who blew a lot of smoke about,suggesting everything on their side was fine,and that it must be to do with the sockets etc at home.
I let you all know what happened when that headache is sorted.
Alfie,
Alfie,
Rule number one of call centres.
If you hear an Indian voice with a Christian name...HANG UP IMEDIATELY!
Rule number 2
If your reeeeally board, see how many different Christian names you can get out of the same opperative. My record is 4. ;D
as with everything technical get a 10 year old round they will sort everything out in minutes :y ;D ;D
Very Very True,my grandson aged 7,has a masters degree in sky programing.
