Omega Help Area => Omega General Help => Topic started by: MV6Danny on 05 February 2012, 23:31:05
Title: Pulling to right under braking
Post by: MV6Danny on 05 February 2012, 23:31:05
My car is pulling to the right under braking and pulling left when driving. :'( I had 4 wheel allignment done a couple of months ago and this did not stop the pulling to the left. I had the left lower arm replaced before the allignment was done after the allignment center advised me the bushes were gone on that side. They did the allignment and it still pulls to the left. I took it back and they then advised me that the right arm needed replacing as well as the track rod end on the right side. Just after a bit of advice really. Would it be advisable to change both arms and both track rod ends aswell as the anti roll bar bushes to try and sort this problem out? If so would it be best to replace them with lemforder parts? I dont plan  on doing this until the end of april as i dont have the cash to do it at the moment and mot due in may. could somebody advise me where to get these parts from at the best price. Thanks Guys :y
Title: Re: Pulling to right under braking
Post by: Entwood on 05 February 2012, 23:40:39
Just my thoughts .....
All steering / suspension parts should be replaced as "pairs" IMHO .. so I would never just replace one wishbone, shock absorber, or spring as examples.
The random changing of parts is always expensive and often fails to fix the problem
I'm no expert on diagnosis, but I have changed wishbones and it is not difficult.
ChrisGixer lives in Oxford and knows more about steering / suspension than most, it might be worth asking him to take a look and give you a PROPER diagnosis of what needs changing.
If it is wishbones there are several threads .. but as a non-expert I fit Lemforders from all german parts ....
http://www.allgermanparts.co.uk/ourshop/prod_906178-Control-arm-lower-NS-Omega-B-Lemforder-27734-02-90-576-788.html
More than willing to help if you are short of tools etc, as I say .. not an expert but have learned a few things and changed a few bits .. :)
Post by: feeutfo on 05 February 2012, 23:54:11
Defo bushes related. I've seen this car on my drive before. It had a Delphi wishbone on one side, with APALLINGLY soft bushes. I guess that's been replaced by a cheapo one, so still not a matching pair either way.
I'd start with a matching pair of Lemforders. If you wanted to add polly bushes too them before fitting that works well. Or get the use put of the original Lemforder bushes first and fit polly later that works too.
Track rods are not so critical to match as a pair, so I'd just change the iffy one. But if your feeling flush fire away and do both as the history isn't known I guess?
Roll bar bushes are not likely related to your issue, but will do no harm.
Delphi track rod ends are ok from any factor.
All German for Lemforder anything.
eBay for polly bushes, there a link on here somewhere.
But, given your set up guys seem to have lead you astray a little, I'd be having a bloody good check over for other faults first, before set up at wim.
As I recall the rear donuts are fubar as well. But check first.
And as said, always change suspension and steering parts in pairs. ALWAYS.  :y
Post by: MV6Danny on 06 February 2012, 15:36:43
So i take it you have worked on my car before i owned it then. The rear donuts? Are they a pain or pretty easy. Will Deffo be replacing both front wishbones with lemforder ones.  :y :y
Post by: feeutfo on 06 February 2012, 22:25:37
no I haven't worked on it, just examined for faults. It's was handling very oddly. Brake, and the steering wheel would twist in your hands and the car would pull to one side. Much like loose wishbone bolts.
Rear bushes are simple in theory. Can range from awkward to a right bloody nuisance, depending how long they've been left. So expect a battle I guess?
Post by: feeutfo on 06 February 2012, 22:30:00
As recent posts elsewhere, it might be worth concidering pre fitting polly to your lemforders. For maximum longevity.
Or get the use out of the original bushes first. Up to you. ;)
Post by: feeutfo on 06 February 2012, 22:55:33
Your welcome to drop by for a check over again to be sure, if you like? :)
Post by: MV6Danny on 07 February 2012, 00:22:53
Ok thanks for the advice. Dont know how far Reading is from swindon but if i am near there i could always drop you a pm to see if you are about thanks. Hopefully gonna try and get to a meet this year so if you are at one of those maybe you could have a look then.  :y
Post by: feeutfo on 07 February 2012, 01:10:23
m4 jcn 11.
I'd give it a bit more urgency tbh. But yes, happy to give it a once over. :)
Post by: MV6Danny on 07 February 2012, 03:40:31
m4 jcn 11.
Not to far then.  :) Maybe i will pop down in a couple of weeks then. will pm you a bit nearer the time. :y I do want to get it sorted out as its doing my head in now. Do you do work on the cars or just check them over. Think i would like to get someone to do the rear bushes for me if you do or know someone else that would be willing to do it. Obviously i would like to help aswell as i do love working on cars.  :y
Post by: Andy B on 07 February 2012, 10:07:40
Do you do work on the cars or just check them over. Think i would like to get someone to do the rear bushes for me if you do or know someone else that would be willing to do it. .....
As far as rear do-nut bushes are concerned there's no one better or more expereinced than Chris!!  ;) ;)
Post by: feeutfo on 07 February 2012, 10:34:09
Yes thankyou B.  :P
Post by: MV6Danny on 07 February 2012, 12:31:52
Yes thankyou B.  :P
:y So would you be interested in doing that for me then chris? What sort of price would i be looking at to have them done? And how much for the parts themselves?  :y
Post by: feeutfo on 07 February 2012, 19:51:43
Some links in the guide (Febi) cheaper. Lemforder from all German parts also, more expensive.
plus a donation to the tool fund, is all I ask, once all is fitted and your happy. ;)
Trying to source some polly for the rear, without much success.
Post by: MV6Danny on 08 February 2012, 02:16:36
Ok Thanks, Just looked at website and found Rear axle mounting bush Lemforder brand 16063 01
Is this what i need? not to bad at 22.81 each :y
Will be in touch once i have them. Do you think it would be worth buying the wishbones aswell and doing them at the same time. Obviously a bigger donation to the tool fund aswell thats if you are ok to do it. Upto you. :y
Speak to you soon. :)
Post by: JamesV6CDX on 08 February 2012, 17:33:04
Danny,
If I am right, you are only 15 miles from me.
Now, whilst Chris is definitely your man for anything suspension related... (I don't undertake suspension work for others)
I have the kit to get the car raised up, and check for obvious faults / bush wear, and would be happy to have a quick look - even if just to assist Chris in knowing what parts he might need to fix it for you? :)
Post by: MV6Danny on 08 February 2012, 18:16:29
Danny,
I think its a bit further than 15 miles but if Thats ok with you and it will help Chris then i would be greatful if you could do that. Are you about next weekend.I will pm you on Friday to arrange a time and get your address. Thanks Danny. :y
Post by: Entwood on 08 February 2012, 23:32:52
Danny,
Have you moved then James ???
http://maps.google.co.uk/maps?hl=en&gs_sm=e&gs_upl=2572l6882l0l7252l21l13l0l8l8l2l512l4386l2-4.7.1.1l20l0&bav=on.2,or.r_gc.r_pw.r_qf.,cf.osb&biw=1024&bih=644&um=1&ie=UTF-8&hl=en&gs_sm=e&gs_upl=2572l6882l0l7252l21l13l0l8l8l2l512l4386l2-4.7.1.1l20l0&bav=on.2,or.r_gc.r_pw.r_qf.,cf.osb&biw=1024&bih=644&um=1&ie=UTF-8&gl=uk&saddr=gloucester&daddr=swindon&dirflg=d&geocode=Kc_y6_b7_XBIMc8Z6CGWm3Ds;KeXk2z1PRHFIMZqUxek3v1al&ei=8gUzT_yjNYKp8AP-uaDnBg&sa=X&oi=geocode_result&ct=title&resnum=1&ved=0CCAQ9w8wAA
just a wee tad/smidgeon more than 15 miles in my book !!!!   :)
Post by: JamesV6CDX on 08 February 2012, 23:34:42
Silly me, I was thinking Cirencester, not Swindon, sorry  :-[
Post by: MV6Danny on 09 February 2012, 01:57:11
Danny,
LOL.  ;D Its double the distance but will still pop down next weekend if thats ok with you james :y
Post by: feeutfo on 09 February 2012, 08:06:15
I'd get under there and check first before splashing out.
He may have had them done, or I've got the wrong car.
... Just to be sure.
Post by: JamesV6CDX on 09 February 2012, 11:16:31
chris I'm not doing anypaid work, so no splashing out required, have just offered to help by having a peek :y
Post by: MV6Danny on 09 February 2012, 19:24:44
like James said he is Just having a look for me to see what i need to get before i come to you. I will pm you to see if you still ok to do it once i have the parts if Thats ok with you Chris. I know something is wrong and needs something replacing.  :y
Post by: feeutfo on 09 February 2012, 20:35:28
Christ, don't worry about who does what. Saves me a job, and it's rather freezing ATM.:)
Post by: JamesV6CDX on 09 February 2012, 21:34:02
;D ;D ;D
In light of the weather, I'm doing a pretty substantial repair in Surrey on Saturday. Time for thermals, I think  :-[
