Omega Help Area => Omega General Help => Topic started by: omega3000 on 06 February 2012, 10:31:00
Title: What do you think ?
Post by: omega3000 on 06 February 2012, 10:31:00
2 hrs taking the diss pack out and this is how it looks .....
(http://i219.photobucket.com/albums/cc41/milleblack/Photo0033.jpg)
(http://i219.photobucket.com/albums/cc41/milleblack/Photo0034.jpg)
Not good , so im guessing this is the problem that was causing my bad running  :-\
Title: Re: What do you think ?
Post by: RobG on 06 February 2012, 10:32:50
In the bin
Post by: omega3000 on 06 February 2012, 10:35:20
Makes sense to the running and no power to number 1 HT as thie rusty bit is where the number 1 HT went into .
Post by: Elite Pete on 06 February 2012, 10:35:36
Door stop ;)
Post by: Elite Pete on 06 February 2012, 10:36:28
You'll have two cylinders down  ;)
Post by: omega3000 on 06 February 2012, 10:39:06
Pig to get the bolts out BUT its out thank god .
Post by: omega3000 on 06 February 2012, 10:40:27
1 and 4 think , thought it sounded rough  ::)
Post by: Elite Pete on 06 February 2012, 10:40:46
When replacing them try a long 8mm socket instead of the torx socket ;)
Post by: twiglet on 06 February 2012, 10:42:56
Seen worse for sale on the bay!  ::) :-X
Post by: omega3000 on 06 February 2012, 10:43:44
I used an 8mm socket pete , the awkward one closest to the engine block in the corner i used 2 small extensions and a knuckle joint while i was kneeling on top of the engine  :D
Post by: Elite Pete on 06 February 2012, 10:55:28
I remove the plenum and inlet manifold, its nice and easy then :y
Post by: 2woody on 06 February 2012, 11:36:01
that's a FAIL.
Post by: Andys VXR on 06 February 2012, 12:27:47
Bung a bit of Blutak in there that will be alright dont know what your worried about :D
Post by: omega3000 on 06 February 2012, 13:27:24
Plenum not removed , i have discovered i have fingers that bend in all directions  :-\
Post by: duggs on 06 February 2012, 15:20:08
Hey !   I've got one of them.....Sits on my desk at work....Makes for a VERY good paper weight.
Post by: omega3000 on 06 February 2012, 15:37:30
Its a weight of my mind getting the thing out of its hiding place  ::) Wondered why mechanics rolled on the floor laughing when asked is it easy to replace  >:(    ;D
Post by: duggs on 06 February 2012, 15:40:25
Knowing that its vunerable to "running water" from the scuttle I've "adapted" a moisture resistant ceiling tile to slide in above it now.
Looks odd but as long as it prevents water to getting to it...job done.
Post by: omega3000 on 06 February 2012, 15:46:01
Why on earth did they weld that metal shroud next to the dispak , if they had made it detachable at the top it would have been an easy job  >:( In my frustration at one point i nearly got the angle grinder out  :o
Post by: Mart280 on 06 February 2012, 20:20:40
Sounds good  :y I sealed mine up with sillicone and denso tape.
Post by: symes on 06 February 2012, 21:14:53
useful as something to practice shot-put with??!! ;D
Post by: dan-eboy on 06 February 2012, 21:28:00
You did it then! Nice one, just gotta get the new one in now! - much easier though!
Post by: omega3000 on 06 February 2012, 21:41:31
Took your advice dan and had plenty of breaks , lifting the bonnet higher gave more room and better light . I did climb on top of the engine ... Now i know how to get to it it should be a lot easier getting it back in  :-X   :y
