Omega Help Area => Omega Electrical and Audio Help => Topic started by: omegafin on 07 February 2012, 14:14:00
Title: CID and NCDC from another car
Post by: omegafin on 07 February 2012, 14:14:00
if I take both CID and NCDC radio from same car and install them to another car they will work without Tech programming,
But if I want later unpair them can it be done if I know donor car's security code , or must car's and radios sec code be same  before I can unpair them ??
Title: Re: CID and NCDC from another car
Post by: Dave DND on 07 February 2012, 14:16:18
To save any future problems, (and there will be some trust me,)
Depair correctly from the donor car with Tech2 before transplanting into new car.
Post by: zirk on 07 February 2012, 14:16:25
Yes and Yes.
Post by: TheBoy on 07 February 2012, 18:38:23
Yes, as long as no telematics involved. Additionally, the configurations need to be the same - Bose, wheel size, engine, gearbox, headlights etc etc.
Post by: omegafin on 07 February 2012, 19:09:29
Donor car is not driveable anymore so it can't be depaired , so can depairing be done in another car if pairing code is known ???
Post by: VXL V6 on 07 February 2012, 19:11:00
Yes
Post by: zirk on 07 February 2012, 19:18:17
Whats the issue with Telematics TB, ie If I took out  paired 2015, CID and Telematics with known code and replaced with 2013 and paired CID also with known code?
Post by: VXL V6 on 07 February 2012, 19:21:04
Think TB means if you move Telematics, CID/GID, NCDC to another vehicle you will need to build yourself a Telematics Sub loom.
Post by: TheBoy on 07 February 2012, 19:26:37
Yes, if all parts of the system are complete (NCDxxxxx, the CDC3, the display, and the telematics)
Post by: zirk on 07 February 2012, 19:29:24
Ah ok, yea thats ok was starting to think theres other issues.
Chris
Post by: TheBoy on 07 February 2012, 19:47:43
Complications with telematics is that telematics must be kept with its associated parts, and the loom changes needed (either to fit or to remove (and replace with bluetooth kit))
