Omega Help Area => Omega General Help => Topic started by: GT on 09 February 2012, 17:23:23
Title: Slight Vibration/Wobble
Post by: GT on 09 February 2012, 17:23:23
Ok Guys,
Getting the bug of actually repairing the omega myself, so i will be posting my questions, and hoping that you omega gurus will point me in the right direction.
When i collected the car for a song, i noticed the steering wheel wobbled, so i had two new tyres fitted, balanced and the tracking done, this has reduced the vibration and wobble loads.
However, when i brake hard i get a wobble through the steering wheel, and traveling along around 45 - 60mph i get the vibration through the car (not loads mind, but noticeable) and if you hold the auto drive stick, you can feel it there too.
so what can it be, track rods and associated equipment, or could it be a propshaft issue....
I am not that mechanicaly minded but i am willing to have a go, opps it, what have igot to loose..
So Gurus, what do you think, and how can i sort it...
regards
GT
Title: Re: Slight Vibration/Wobble
Post by: ndmv6 on 09 February 2012, 18:00:22
wobble on braking is more than likely warped front discs.
vibration at speed could be the 2 other tyres that were not balanced...
Post by: cem_devecioglu on 09 February 2012, 18:07:56
yep..as said warped discs..
rears also may need geometry..
also you can check the shaft balance by lifting up/jack the rear and turn the wheels in the gear.. (turn off the traction control- and please be careful dont try high revs/speeds)   but before you need to be sure rear balance is ok
Post by: TheBoy on 09 February 2012, 18:08:01
Vibration through car is likely rear balancing, or damaged rims.  Omega props are not known to be problematic.
Vibratin under braking can be warped discs, or worn suspension components.
Post by: cem_devecioglu on 09 February 2012, 18:09:42
not the ones with accidents :-\  I got a faulty one during manual conversion :(
Post by: GT on 09 February 2012, 18:17:03
Ok Guys, not the propshaft then, so it could be the front disks, would these off fleebay be any good
Vauxhall Omega Estate Mintex Front Brake Pads+ Discs item number : 110732292521 or should i get another make
GT
Post by: Reefpotato on 09 February 2012, 18:29:40
Hi GT  :y
I think from memory, wobbble at speed when braking,if its not warped discs, could be tie rod bushes, had this problem on an old 3ltr Capri ghia, it had wide rims and  tyres on it and kept knocking out these bushes,apparently the same tie rod was fitted to an escort, which was half the wieght on the front, and the wide rims did it no favours,not sure but certainly sounds like the same problem i had :-) I think you can check by jacking the car and trying to move the wheel towards the front and rear of the car,shouldnt be much play in either direction.
Im sure to be corrected if wrong  ;D
Post by: tunnie on 09 February 2012, 18:31:29
GT
For about the same price you can get GM ones. (on trade card of course)
Post by: TheBoy on 09 February 2012, 19:07:50
Mintex discs and pads for the Omega are utter shite. Avoid.
GM ones for road use are hard to beat, and what I know use on both mine. Yet to destroy a GM one, never had a pattern set last more than 3 months. OK, replaced under warranty, but you still have to buy a set whilst waiting for the manufacturer to check and replace them.
Post by: Entwood on 09 February 2012, 19:11:57
"Warped" discs are actually extremely rare, on any car, but there are several reasons why "judder" when braking can occur. Explained in far better detail here ..
http://www.powerbrake.co.za/tech_info/tech_01_judder.htm
Now this won't cure the problem, but understanding it may well prevent it re-occuring in the future ...
Post by: TheBoy on 09 February 2012, 20:06:55
Indeed, but the phrase is taken to mean any runout issues on it.
Some discs are prone...  ...pretty much any non-track pattern ones...
