Chat Area => General Discussion Area => Topic started by: V6drift on 23 March 2008, 19:29:12
Title: been spending.....
Post by: V6drift on 23 March 2008, 19:29:12
ive just got round to getting the rocker cover gaskets, plugs and cambelt kit fitted   ;)
i bought genuine GM parts and got a mate to fit them (15 years ex vauxhall mechanic) at a small cost of £150 ::)
he said the gaskets were like plastic and the plugs and leads were totally submerged in oil but it still ran smooth  :o
but now i have a problem, now its dry its got a missfire from tickover to 2500rpm  >:(
are the HT leads knackered now :question
Title: Re: been spending.....
Post by: Martin_1962 on 23 March 2008, 20:20:51
Possibly - or an air leak
Post by: V6drift on 24 March 2008, 16:32:04
it wont even run now when its hot   >:(
runs not too bad when cold but as it gets hot its not on 6  :-/
how could it have been right before the rocker, plugs and cambelt job but not anymore  :question
if i get some new ht leads to try what sort of job is it to change them  :question
please help as its starting to p--- me off already  >:(
Post by: albitz on 24 March 2008, 16:38:36
it could also be the dis pack (or both) it is awkward to change the leads but not technically difficult in any way.im sure there are guides / photos etc on the site which will assist. :y.........if its running worse after being worked on you might want to check,have the plug leads been put back in the correct order,have the correct type of plugs been used and has the cambelt definetely been fitted correctly.
Post by: V6drift on 24 March 2008, 16:52:17
it ran perfect before the work,
i had it worked on by an ex vauxhall mechanic so it should have been done right,
the only difference is the spark plug ports were full of oil and now they are dry,
also on one of the ht leads, some of the rubber shield on the plug end is missing,
any ideas?
Post by: Marks DTM Calib on 24 March 2008, 17:10:44
any ideas?
You are to trusting.....
Does it miss fire at all on tick over?
Post by: V6drift on 24 March 2008, 17:15:15
yes it is missing on tickover,
to start with it was on tickover and upto 2k but only when it was hot,
now its missing on tickover and all the way through the revs all of the time...
Post by: keith2.2 on 24 March 2008, 18:51:58
can't you ask your mate who was a vx mechanic for 15 yrs?
Post by: Marks DTM Calib on 24 March 2008, 19:19:38
Sounds like hes connected the plug leads on the dis pack for the 2-4-6 bank up wrong.
If he has, dont run it or you could hole a piston.
Post by: V6drift on 25 March 2008, 21:20:05
well its sorted (more bodged to be honest)
but at least its confirmed that a ht lead is faulty,
i,ll get some bought asap...
Post by: Marks DTM Calib on 25 March 2008, 21:21:01
Dont buy genuine, get some Bosch ones...
Post by: V6drift on 25 March 2008, 21:33:33
thanks for the advice,
ive seen bosch ones on an ebay shop for £39.95,
does that sound resonable???
