Omega Help Area => Omega Electrical and Audio Help => Topic started by: markspark on 14 February 2012, 23:46:18
Hi how do i reset my rear blind on a 2000 elite the blind goes up when i press the button but when i press the button for it to go down it does that but then comes back up 1/4 of the way up it does every time its used
TIA
suspect its a stripdown job...
i will give that a try in a couple of weeks thanks for the reply :)
I had roughly the same thing, bugged me as I had no time to strip it. 3 weeks later had new battery fitted to the car, & has been fine ever since, maybe worth pulling the power for a couple of minutes?
hth
i will give that a try 1st as im not really well enough to do much more ive only just come out of hosptal after having heart attack
Oh dear, that's not so good :o
On the plus side, you're out of hospital :y
Take care and good luck.
If you're stuck I'm sure there will be someone in the area could give you a hand.
Hope all is well mate, good luck :y
I'd sit an relax in the front room rather than argue with a rear blind/parcel shelf ;). I'd come and give you a lift but will be busy for the next week/10 days and then back in work.
Get well soon! :y
