Chat Area => General Car Chat => Topic started by: danzigfan on 15 February 2012, 10:32:55
Title: A Peugeot 307 question
Post by: danzigfan on 15 February 2012, 10:32:55
I wanted to help coworker and it seems I screwed up something.
Lock/unlock buttons were worn out so I ordered a new housing and thought thay's it.
As always follows "BUT"....
Lock/unlock still works but imobiliser doesn't let engine to start  :'(
I followed this manual :
PEUGEOT 307 PLIP  - Remote Key
Programming
1. Turn the Ignition switch to the ON
position using the first key.
2. Press the LOCK button for 10 seconds.
3. Remove the key and wait for 10 seconds.
4. Check the Plip key operation.
5. Repeat for second Plip key if required.
6. Turn the ignition OFF
It works fine, cranking and ignition ferfectly but when I lock the car and unlock it again, it's just cranking, no ignition.
Anyone knows the solution?
Beside going to stealers? Thanks, Stan
Title: Re: A Peugeot 307 question
Post by: Lazydocker on 15 February 2012, 10:39:49
Sounds like there's an immobiliser chip that you haven't transferred from the old housing to the new
Post by: danzigfan on 15 February 2012, 10:45:54
There was only steel key part and little circuit board inside the housing. Did I miss something there?  :-\
Post by: Lazydocker on 15 February 2012, 10:49:26
Possibly... On the Omega there's a little transponder chip, only about 2mm by 5mm (IIRC). The Pugeot may have the same setup ;)
Post by: danzigfan on 15 February 2012, 10:54:18
Than....stupid me to help...I guess, or unhelp.
Is it maybe hidden somewhere in housing? Just guessing
Post by: Lazydocker on 15 February 2012, 11:00:47
Glued in I expect :-\
Edit: I've just taken my van key apart and I can't see one in there so not sure
Post by: danzigfan on 15 February 2012, 11:06:34
The same with that one. Nothing else inside.
Just crossed my mind, could it be in other part of housing, the one without buttons?
Couse I still have old housing at home. Worth to give a try
Post by: Lazydocker on 15 February 2012, 11:08:42
If you still have the old housing then try using the new key with the old housing held next to it. If it starts OK then it confirms that there's a transponder in the old housing ;)
I take it that the car starts fine with the spare/other key?
Post by: danzigfan on 15 February 2012, 11:23:00
Yes, it starts without problem
Post by: Lazydocker on 15 February 2012, 11:24:13
Try as I suggested then, with the old housing held/taped to the new key (in the same position). If it works, there's a transponder ;)
Post by: danzigfan on 15 February 2012, 11:39:25
Will do it this way. I hope it'll work.
Thank you for help
Post by: Andy B on 15 February 2012, 11:55:08
Don't know if it's any help, but I had a Peugeot scooter. That had a chip built into the key, but also had a 'master' red key, you'd to start the scooter with the red key then within ? seconds start the scooter with your new key to 'code it'  :-\
Post by: Lazydocker on 15 February 2012, 12:04:39
Like the old Fords ;)
Don't think they kept that up... Certainly don't have it on the van :-\
Post by: danzigfan on 15 February 2012, 12:23:50
No red master key here. Just original without buttons on it. Thanks for tip
